SOUND FROM THE STEERING !!!
08.05.2020 14:13 # 1
Eleanor_
Hello friends, I think there is something wrong with the steering wheel of my vehicle.
Although the steering wheel's oil did not decrease at all, recently, whirling noises started to occur while driving the vehicle, and although I did not turn the steering wheel very little, while we parked the vehicle, we are pulling more steering wheel, while it sounds like a strain and friction. If there is a friend who knows the reason, I would be very glad if he bought the car for 1 month, there was nothing, but for a couple of weeks, there were some problems, I did not understand.
08.05.2020 14:13 # 2
hasimayaz
there may be a shortage of tires. May come with heat on very slippery asphalt
08.05.2020 14:13 # 3
Eleanor_
No, my brother, I come directly from the steering wheel and the windows are closed and I am officially hearing from the steering wheel.
08.05.2020 14:13 # 4
BuRCaK
very few humming sounds in me. Could the pump fail, or more than 24000 cars. I'm very sorry.
08.05.2020 14:13 # 5
Eleanor_
I am afraid of the pump too, I hope it won't cause any problems
08.05.2020 14:13 # 6
peugeotefe
problem most likely caused by the steering pump
08.05.2020 14:13 # 7
+90 312 2785898 call helps this number hakan master .. your probe is likely to be a pump
08.05.2020 14:13 # 8
Eleanor_
Well, is this repair pump being repaired or do I need to change it?
08.05.2020 14:13 # 9
peugeotefe
they do the repair, but i heard you didn't
08.05.2020 14:13 # 10
Eleanor_
I also noticed that when you start the first car in the morning, there is nothing but it starts when 200-300 mt goes.
08.05.2020 14:13 # 11
peugeotefe
If you are in Istanbul, I can help if you come with your vehicle.
08.05.2020 14:13 # 12
okankrgz
There is no die base to be made from the steering pump, I think pump connection pipes etc. Have a check first leak or replace hoses, I do not think that the pump will easily malfunction.
08.05.2020 14:13 # 13
bulent 77
high probability comes from rods
08.05.2020 14:13 # 14
Eleanor_
Thanks for your valuable comments, let me improve my economic situation a little bit. I will show my first job.
08.05.2020 14:13 # 15
sfyucedag
I think you shouldn't let them go down under the vehicle and say the pump without looking at the rods and the trays, because the sound you mentioned was like the door creak, it was one of the trays. If they look at the bottom in a shop that makes rot-balancing adjustments before the ranking, they will tell you moments.
Get well soon.
08.05.2020 14:13 # 16
Eleanor_
[QUOTE = sfyucedag] I think you shouldn't let them go down under the vehicle and say the pump without looking at the rot heads and tables, I think it was from the tables as I said the sound of the door creak. The service tells you that if they look at the bottom of a shop that makes rot-balance adjustments, they will understand it.
Get well soon. [/ QUOTE]
Thank you very much for your help, just as you said, a sound like a door creak, I will go to a rotman tomorrow and let me see it.
