SOUND FROM THE STEER OF THE PEUGEOT 206 |
| 08.05.2020 20:09 | # 1 |
I have a 2000 model peugeot 206 1.6 motor vehicle.When my car turns the steering wheel right or left, it sounds like a plug and click, if anybody knows about it, it can be helped.
| 08.05.2020 20:09 | # 2 |
sonerkyl |
first of all welcome problem most likely z rot - rod shaft - have the rot head checked. If there is no sound in the steering wheel other than right and left, of course
| 08.05.2020 20:09 | # 3 |
I got it, soner, no problem when the steering wheel is straight. He only does it when he turns the vehicle right or left when parking. last year, I changed the rod rod rod rod head again one year.
| 08.05.2020 20:09 | # 4 |
sonerkyl |
My teacher broke down, after there were such roads in our country, I changed the swing (front plate) twice in 2 years. most likely z rot is broken in your vehicle
| 08.05.2020 20:09 | # 5 |
Thank you, Soner Bey, I will go to the industry tomorrow.
| 08.05.2020 20:09 | # 6 |
I do not know if it is the same, but my father was in the fiorino, this problem started to come even in small movements, the damper pads changed, there was no problem.
| 08.05.2020 20:09 | # 7 |
I wonder if it has anything to do with the axle
| 08.05.2020 20:09 | # 8 |
sonerkyl |
No teacher, if the axle is troubled, the vehicle will wobble and you will feel it accelerated. and when the axle is empty, it makes a sound on departures.
| 08.05.2020 20:09 | # 9 |
no soner only happens when i park ... how the axle in the gap makes a sound
| 08.05.2020 20:09 | # 10 |
sonerkyl |
There is a sound called Lok Lok, and there is vibration in the vehicle. As I said, only z-rot is troubled you
| 08.05.2020 20:09 | # 11 |
ok thank you teacher
| 08.05.2020 20:09 | # 12 |
sa went to industry on saturday. The reason for the noise from the steering wheel was fixed when the new tire was installed due to the melting of the front wheel tires and one of them being warped.
| 08.05.2020 20:09 | # 13 |
sonerkyl |
How old would the tires be? I think that when the wires break, it sounds like this.
| 08.05.2020 20:09 | # 14 |
The tires were 2 years old, because one side of the left front tire melted too much, the wheel turned halfway and the vehicle turned halfway, making the sound disappear because it turned halfway.
| 08.05.2020 20:09 | # 15 |
sonerkyl |
I understand, teacher, thanks for the feedback and information.
| 08.05.2020 20:09 | # 16 |
YOU'RE WELCOME
