Sound from the right side of the hood |
| 08.05.2020 19:34 | # 1 |
| 08.05.2020 19:34 | # 2 |
It comes from the steering pump.
| 08.05.2020 19:34 | # 3 |
If it looks like a light sewing machine sound, it comes from lpg injectors.
| 08.05.2020 19:34 | # 4 |
Yes, just like the sound of the sewing machine came out to the oeta after changing the motor oil of gerwkir
| 08.05.2020 19:34 | # 5 |
Injector sound may vary depending on the position of the injector, depending on the brand of the lpg kit. Some brands work with sound, others make sounds due to poor assembly. Cooling in the air may have affected the sound. I don't think it has anything to do with oil change. But have some intermediate injectors checked for your peace of mind. When was the lpg attached to the vehicle? Over time, the gasket at the tip of the injectors etc. sound may increase due to wear of things.
| 08.05.2020 19:34 | # 6 |
KILIC |
Most likely that sound was coming before. Since you have changed the oil, the engine noise has decreased slightly and you should start to hear this sound. It is the sound of lpg injectors
| 08.05.2020 19:34 | # 7 |
I guess it was at least 4-5 years since I bought the car and it was 1.5 years. injectors may be outdated. However, when the car gets hot, is it necessary to change it immediately? or will I go if I change it ??
