Sound from the Right Front Wheel
08.05.2020 17:29 # 1
MuRaTTTT
It seems that a few topics have been opened in the forum before, but it does not seem to have been fully achieved. There are opinions that it may be from the axle ball. I want to get your valuable comments.
08.05.2020 17:29 # 2
hsnsnl
my voice from the shock absorber tray .. whatever side is broken, when it breaks to the side, if it is light bump, it makes a sound in the place where you landed
08.05.2020 17:29 # 3
MuRaTTTT
this is a different point of view:) & nbsp;
in my guess, I guess I would go to industry like this in the direction but I would like to say ten thanks
08.05.2020 17:29 # 4
MagicPerformance
hanger rod :)
08.05.2020 17:29 # 5
ismailkaya
& nbsp; Get well :))) I think if you do the front & nbsp; & nbsp; hold the wheel with both hands, shake it and see if it is clicking, the axle heads need to change.
08.05.2020 17:29 # 6
MuRaTTTT
: D Which one is different, everyone is saying different things
08.05.2020 17:29 # 7
plawert
Let a master see it, buddy)
08.05.2020 17:29 # 8
cocomo
brother, he was coming from me, a sound like a plug and play, the master who put the ear upside down in the previous repair .. when it was corrected ..
but it may come from places like zrot, tie rod head, swing. take them to the masters and lift them up.
08.05.2020 17:29 # 9
MuRaTTTT
[QUOTE = ismailkaya] & nbsp; Get well :))) I think if you are doing the front & nbsp; & nbsp; hold the wheel with both hands, shake it, click the axle heads need to change. [/ QUOTE]
I tried last night but no sound :)
08.05.2020 17:29 # 10
ismailkaya
You shake slowly, you will be hard, shake quickly in the direction the steering wheel turns
08.05.2020 17:29 # 11
SDYMZ
I think you show how many masters you are. the axle is not cheap and doesn't break easily
08.05.2020 17:29 # 12
MuRaTTTT
you shake slowly, you will be hard, shake quickly in the direction the steering wheel turns
I shook it for about 3 minutes, but it was not enough.
08.05.2020 17:29 # 13
emre_akdag
Now I know you will get more confused, but as the mechanical information turns the steering wheel right down to its root, the sounds that come as `` plug-in '' or whisper come from the steering pump. when the steering makes the right or right left, the pump has difficulty working and makes strange noises. this is a possible normal situation. Even in zero vehicles, this sounds.
& nbsp;
However, you still show it to a mechanic, my friend. Maybe there is a problem with the front team.
08.05.2020 17:29 # 14
MuRaTTTT
[QUOTE = toretto16] I know you will get more confused now, but as the mechanical information turns the steering wheel right down to its root, the sounds that come as 'plug-in' or whisper come from the steering pump. when the steering makes the right or right left, the pump has difficulty working and makes strange noises. this is a possible normal situation. Even in zero vehicles, this sounds.
& nbsp;
However, you still show it to a mechanic, my friend. Maybe there is a problem with the front team. / div>
13.08.2022 05:27 # 15
TitiCan5
The axle head may be stuck, if it is watered and rusted, it hangs and makes noise.
