Sound from the left front wheel?
08.05.2020 19:13 # 1
vpro
While friends are going straight from the left front wheel, there is a click (metallic) sound at normal speeds, as if there is a stone in it (no shaking or shaking). It is coming. Somewhere, the balance weight is not sticking well, I heard that you are making a sound.
08.05.2020 19:13 # 2
GokhaN
I do not know exactly whether the balance weight may be, but if the glass is closed, the exhaust may be shaking, even if it is shaking, it can make sound when it is idle if the hook is not hanged on the tire.
08.05.2020 19:13 # 3
Faruk
it is the axle ball if it does not come when idle.
I had a similar situation. The middle axle ball changed.
08.05.2020 19:13 # 4
vpro
I do not pay attention to the sound pressure when the window is closed.
08.05.2020 19:13 # 5
talip206
[QUOTE = vpro] It doesn't come when the window is closed.
If the rims are not steel, its normal rim is the metal hub in the middle of the rim, loosening. Sometimes it comes out and falls between the rim cover. Check it out.
08.05.2020 19:13 # 6
vpro
[QUOTE = talip206] [QUOTE = vpro] It does not come when the window is closed
If the rims are not steel, its normal rim is the metal hub in the middle of the rim, loosening. Sometimes it comes out and falls between the rim cover. Check it out. [/ QUOTE]
Sir, where are the original wheels?
08.05.2020 19:13 # 7
talip206
Yes, under the emblem on the plastic wheel cover. You see it when you remove the plastic cover. There is a metal cover right in the middle of the jantine and it makes a sound if it loosens. Mine was making a sound that fell between the wheel cover and it made a metal-like sound talip206 2015-04-20 23:06:21
08.05.2020 19:13 # 8
vpro
let me see tomorrow teacher
08.05.2020 19:14 # 9
themurat54
Just like that the cover is making its sound happened to me.
08.05.2020 19:14 # 10
erdemumut
If [QUOTE = Faruk] is coming to the gas when it is idle, it is the axle ball.
I had a similar situation with the middle axle ball changed. [/ QUOTE]
just like turning it to the left and right, if it clicks, I would like to have a look at the outer axle bellows.
08.05.2020 19:14 # 11
vpro
The lining is over the left on the wheel: D is interrupted, the noise is cut again: D is 150 pieces of paper, which is expensive.
On the left, the left is over, right, some of it was standing, the master will adjust when the brake is adjusted.
08.05.2020 19:14 # 12
vpro
Friends, I showed the master today, said do you think it would make sense to lift it on the lift?
08.05.2020 19:14 # 13
When I turn the steering wheel on me, I think it sounds like plug and play.
08.05.2020 19:14 # 14
Viruse
Friends, there is a subject like this. Since they removed a carcinogenic substance used in brake axes in the past, the metal density of the pads has started to become more, which comes as a rubbing sound on the move. I started doing it a week after replacing the pads. I went to the service again and they replaced the pads without question with Bosch. It has not been 1000 km yet, the same sound started to be heard. I wonder how would you suggest a solution to this?
08.05.2020 19:14 # 15
berk2309
sometimes it is too hard to press and pull the brake.
08.05.2020 19:14 # 16
vpro
What if the problem is not the linings and the rods still couldn't be from the wheel bearing friends
08.05.2020 19:14 # 17
vpro
The problem still continues, guys Confused The sound comes at about 90 km / h and the window is open (reflected from the median or wall). When turning to the right, the sound is obvious (click and click like two metallic coins hit each other). What do you think is the problem? Cry (I couldn't show the master, because of the finals)
No sound is interrupted when it is wasted.
vPro 2015-05-12 21:09:54
08.05.2020 19:14 # 18
madblueblacksea
Try to hit the jack and look at the vehicle by turning the tire. There was no tire, there is abrasion, rubbing, bumps, something. What we say to you here is empty. First try to catch the end of a rope and bring the rest from us. With all the recipes, we'll throw it and keep it.
08.05.2020 19:14 # 19
vpro
[QUOTE = madblueblacksea] Hit the vehicle and try to look at it by turning the tire. There was no tire, there is abrasion, rubbing, bumps, something. What we say to you here is empty. First try to catch the end of a rope and bring the rest from us. With all these recipes, we keep throwing it and the room will not work for you [/ QUOTE]
I will not make a master. Can I try to lift the wheel on the wheel and there is no sound, it makes me very angry. vPro 2015-05-13 22:47:47
08.05.2020 19:14 # 20
talip206
Replace lastigi with spare wheel. No harm from trying, at least without expense
Page : / 2
