Sound from the left front wheel
08.05.2020 19:54 # 1
Dlkrn_48
When the friends slow down as if they are rubbing on a wire in the left front wheel, it slows down and speeds up when it slows down :) This sound is constantly on the straight road and turning to the right, but when turning slightly to the left or touching the brake, the sound is heard. Does anyone have information ?
08.05.2020 19:54 # 2
ersinyildiz
Get well, I have the same problem. I suspect the pads. In a few days, the vehicle will go into maintenance, and if I can get it, I will inform you about the problem there.
08.05.2020 19:54 # 3
Dlkrn_48
[QUOTE = ersinyildiz] Get well, I have the same problem. I suspect the pads. In a few days, the vehicle will be in maintenance, if I can get it, I will inform you about the problem there. [/ QUOTE]
Master, I haven't figured it out yet, but if you want, take a look at this.
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=42547&title=inceden-surekli-gelen-cik-cik-sesi-cozul
08.05.2020 19:54 # 4
ersinyildiz
[QUOTE = Dlkrn_48] [QUOTE = ersinyildiz] Get well, I have the same problem. I suspect the pads. In a few days, the vehicle will be in maintenance, if I can get it, I will inform you about the problem there. [/ QUOTE]
I examined that topic, and my teacher was not close to my problem. I showed it to the master yesterday. He said that the sets on the pads made. It was not a serious problem for me, the master said we will look at the lining of the lining, and I left.
08.05.2020 19:54 # 5
TooJohn
I had the same problem, the sound was cut when I attached it to the original pad.
