SOUND FROM THE LEFT BACK
08.05.2020 19:44 # 1
rufuk
Hi ,
From the left back, it sounds as if the two metals hit each other as if the cat cut in between. Is this the hell that faced a problem in this way? What could be the problem?
Thanks,
08.05.2020 19:44 # 2
I think if the problem is a chronic problem like torsion, the estimated cost is around 600-800 TL
08.05.2020 19:44 # 3
ALLEX
[QUOTE = sonerkyl] I guess if the problem is a chronic problem like torsion, the estimated cost is around 600-800 TL [/ QUOTE]
I definitely agree, you can see the condition of the rear wheel while it is already inserted.
Someone who came to the industry with similar complaints came across something very abnormal.
The men did not tighten the wheel bolts while wearing the rim. The sound was caused by the large rim.
While searching for the problem, step by step control is the most correct.
The problem may even occur in rear shock absorber connections.
Get well soon. If you share the problem under this heading, it will benefit other friends and shed light.
Respect for ...
