Sound from the gearbox
08.05.2020 20:43 # 1
ertugrulfurkan01
I just joined your friends. I have 206 cars in 2003. I decided to sell them. This sound was coming in 4th gear. I asked the master while buying. He said nothing will happen. The former owner had this voice too. I also used 35 thousand kilometers. With this voice, I had no trouble. But now when I decide to sell the car, I tell those who come to look at this voice. Everyone is stepping back. I say you can show it to the master you want, but they give up taking it anyway. They like everything. But they give up because of this sound. Lastly, I said I would consider the cost of the sound from this gearbox at the price. Let me ask you this sound, how much does this cost? Lastly, let me say that this voice becomes evident at low speed when the 4th gear shifts as the speed increases, the sound is cut when the clutch is pressed. Especially between 50 and 70 kilometers.
08.05.2020 20:43 # 2
First of all, welcome to us. My brother is most likely the problem looks like a 4-gear synchromanc or gear. secromenç price 150 tl shaman stroke stroke dismantling etc. If there is no other problem, it will cost between 500-1000 TL. min. You will review 500 TL, brother.
08.05.2020 20:43 # 3
onlycihan
I had this sound in 1st and 2nd gear, first synchromesh shifted, my gear shifts got stiff, 1st gear did not go, pressure pads etc. all changed, I reset the last gearbox completely. think about 500 TL better than the price. Maybe it would be good to have the gearbox oil change its oil or something. Put a quality oil.
08.05.2020 20:43 # 4
ertugrulfurkan01
First of all, I would like to thank you for your answers. I thought it would cost 2000-2500 TL in my head, but as you say, it would be between 500 and 1000 TL.
08.05.2020 20:43 # 5
ertugrulfurkan01
I want to add one more thing. I couldn't sell the car. Will this sound make anything happen in the future? Though nothing happened so far I said let me ask you
08.05.2020 20:43 # 6
onlycihan
As I said you will ride, renew your oil or something, continue to ride, there is no problem other than the sound.
08.05.2020 20:43 # 7
ertugrulfurkan01
No, hodja, my goal is to sell, but I couldn't sell anything. I am going to trade for the first time.
08.05.2020 20:43 # 8
onlycihan
I don't think so. the sound coming from my vehicle was even suppressing the sound of the engine in the 1st and 2nd gears, it sounded like the tofaş engine. Upload here will give more experienced friends ideas.
08.05.2020 20:43 # 9
ertugrulfurkan01
Now a man called to pick up the car. He would call his master and ask for his cost. Let's see what he will say. According to him I will write the price here
08.05.2020 20:43 # 10
onlycihan
Let's say about you, there is no more than 1000 TL. Amamraf already sell zero gearbox for 1250 TL. The maximum workmanship may be over 250 TL.
08.05.2020 20:43 # 11
ertugrulfurkan01
He said that there is a cost of 700 TL and 1500 TL. I couldn't trust him.
08.05.2020 20:43 # 12
onlycihan
If the airbag lamp is on, it is a more important problem than that gearbox. It points to the 2000 malfunction and currently the airbags are very dangerous in case of an accident.
08.05.2020 20:43 # 13
ertugrulfurkan01
I wonder how much it will cost me. When I first made this light, I got it connected to the pc. It is on because of the seat belt.
08.05.2020 20:43 # 14
ertugrulfurkan01
Now I have done a research.
08.05.2020 20:43 # 15
ertugrulfurkan01
Hodja, this is where the airbag socket is. improved. I'll look at her soon
08.05.2020 20:43 # 16
My teacher is unlikely to be a socket if there is no airbag in the seat. When I opened the cover under the steering wheel, there were sockets when I bought it, it was burning, the socket was loose, and the seat was extinguished.
08.05.2020 20:43 # 17
ertugrulfurkan01
A friend in the forum has done the disassembly work. He removed the steering wheel or something. Is it possible to disassemble the box below without removing the steering wheel? There is no signs of malfunction though the build socket is ya.com2000 ertugrulfurkan01 2018-01-19 09:57:13
08.05.2020 20:43 # 18
no need to disassemble the steering wheel, bro. The com2000 faulty headlight signals may malfunction and there is an airbag winding if it is broken, it may not cause trouble in the headlight signal arms.
08.05.2020 20:43 # 19
ertugrulfurkan01
I'm doing the dismantling work at the appropriate time today. A friend said there is a socket where the seat belt is wrapped. Is that true? When I connected it to the pc, it said the seat belt error for this airbag
08.05.2020 20:43 # 20
As I said, my teacher, if there is no airbag in the seat, it is not normal to give this error. Because in my vehicle, I had completely removed the seats when performing detailed cleaning in the summer. There was no socket connection.
Page : / 2
