SOUND FROM THE GAS PEDAL OF THE CAR
08.05.2020 18:53 # 1
ergunndurmazz
WHEN THE CAR DOES A LIGHTWEIGHT OR DEFECTIVE ROAD, DOES A CLICK SOUND UNDER THE GAS PEDAL AND IS THERE A PROBLEM OR A COMMENTARY THAT IS A DIFFERENT SOUND ???
08.05.2020 18:53 # 2
Buspiron
Are you sure that it is under the accelerator pedal so that there is no transmission, there was a sound in me, the transmission was cutting the pressure, the output came out ..: S
08.05.2020 18:53 # 3
ergunndurmazz
brother comes under the accelerator pedal or not the transmission, so the gearbox is solid.
08.05.2020 18:53 # 4
ergunndurmazz
Did you sound when you entered the grounded road or something?
08.05.2020 18:53 # 5
peugeotefe
That sound is the indispensable discomfort of the 106's. If you have a sports spring or press spring, that is, if your car is flat, the sound comes from the steering box.
08.05.2020 18:53 # 6
outlaw
[QUOTE = peugeotefe] It is the indispensable discomfort of the 106s. If you have a sports spring or press spring, that is, your car is flat, the sound comes from the steering wheel [/ QUOTE]
Thumbs Up EXACTLY
08.05.2020 18:53 # 7
Barbar_35
http://forum.peugeotturkey.com/forum_posts.asp?tıd=37710&title=tekleme-stop-etme-cekis-problemi-sorunlarimi-coz
I also mentioned here, the click sign will change :) In such a damn place, we rolled up the sleeves with my master, we started at 10 in the morning and the evening ended at 10 in the evening: D asked for 200 workmanship to wear in Izmir, my master did not fit the original part, we did something more robust in the lathe.
