Sound from the front team
08.05.2020 17:51 # 1
kasirga16
Hello friends, there is a sound in my 307 sw automatic car that does not exist when driving on the straight road, but on the right side of the ramp (especially while giving gas) mute box. you may cause respect ..
08.05.2020 17:51 # 2
Bunyamin.Kar
Teacher, while accelerating in the vehicle, is there a tremor between 80 and 90 km? If there is any, get past, I have it on my head right now I have been dealing for 3-4 weeks
08.05.2020 17:51 # 3
silivriserdar
There are those sounds in my car and I couldn't find the reason what I did. I did not find that I took it to 2 masters, but not from the front team and not axle. It comes especially when it is slow and the gear is idle. There is nothing we have seen and removed the left tire. The rods changed again, the sound continued. But the master says there is nothing in the axle. I do not mind anymore, we will find a cure where it stands and there is nothing to do.
08.05.2020 17:51 # 4
kasirga16
silivriserdar friend, this voice is getting new. This sound comes when the gearbox shifts down automatically when starting off the ramp. It seems like something is buzzing like humming. I'll take it to the master.
08.05.2020 17:51 # 5
error
If the felts are finished, how many thousandths of the vehicle? and have you been in heavy maintenance so far?
08.05.2020 17:51 # 6
kasirga16
vehicle 17000 km errör teacher, I showed the master yesterday, thank you to Cüneyt and Kenan Usta from Bursa - Ustaeller service. There was a buzzing and friction sound in the ramp outputs caused by the engine hanging down due to the wear of the engine ears. Shaving was done in the place causing the sound. The voice ceased. I will change the ears in the next stages.
08.05.2020 17:51 # 7
silivriserdar
Well, they have found your problem, my master has not even found it. I don't care much about it anymore, where it stops, it turns out what the problem is now.
08.05.2020 17:51 # 8
eserxxx
I hear a sound coming from the front wheels. When moving the vehicle for the first time, when turning right, left, into a light pit, a bump or something, there is a sound like plug and play. The front team has changed as it is, my master has done quite a bit of research, but he could not find the source of the sound.
