Sound from the Front Chest
08.05.2020 20:43 # 1
kayaca
First of all, I have a problem, say good day, friends stop the car and lift it at 1, as if there are rattles in the chest, I throw it at 2, it continues to rattling, this sound comes up until 2 o'clock. How can we solve the car?
08.05.2020 20:43 # 2
those sounds are coming behind the central ventilation. Remove the tape and check the tape where it is the tape.
08.05.2020 20:43 # 3
kayaca
[QUOTE = sonerkyl] those sounds are coming behind the center ventilation. Remove the tape and check the tape where it is tape. Let's look at it.
May I be a master
08.05.2020 20:43 # 4
boruc
A situation similar to what happens in my vehicle is at around 1500-1800, as if a rumbling sound is coming from inside the instrument panel. No problems in other transfers. I couldn't find the reason
I'm skeptical of the tachometer stepper motor but I'm not sure
08.05.2020 20:43 # 5
kayaca
[QUOTE = boruc] A situation similar to what happens in my vehicle is at around 1500-1800, as if a rumble sounds from inside the instrument panel. No problems in other transfers. I couldn't find the reason
I'm skeptical about the tachometer stepper motor but I'm not sure [/ QUOTE],
Well, I got nervous at night, I punched the chest, while I was going on the road, he continued to take off again, he would take me out soon.
08.05.2020 20:43 # 6
erdiano
Hello friends. I was thinking about opening a title related to this problem. Big smile
In me, on the roads with key stones, especially the uphill 2nd gear, without forcing the car, there is a grin from the front chest, especially from the torpedo sides. But sometimes it is so disturbing that I can't tell. I am already obsessed with the sound of the car, this prick makes me crazy. I would like to remove the front chest and fix whatever is shaking, if the friends who have knowledge and advice on this issue help, we will consciously do the application.
erdiano 2018-01-18 12:57:23
08.05.2020 20:43 # 7
onlycihan
Silicone sprays can sometimes work. 206s, whatever 307, a higher vehicle should not be such problems. When I come from the tape part of the vehicle in the cold, when I touch the tape or press it towards the chest, the sound stops, I feel cold, I disassembled it before disassembly again. air conditioning and central ventilation are the main sound areas, all of them are interconnected parts one by one, to wrap the hard materials that will make distress noise, gathering again reduces the noise
08.05.2020 20:43 # 8
talip206
When the sound comes, touch the light lamp and see if a sound will go away.
08.05.2020 20:43 # 9
boruc
[QUOTE = talip206] Touch the headlamp when it sounds, let's see if a sound will go. [/ QUOTE]
I have tried it before, I tried again today but in vain :)
I'm sure it's coming from inside the dashboard
08.05.2020 20:43 # 10
kayaca
Well, it comes from my chest, but I couldn't get it out. Who knows how to find it? Is it difficult to disassemble the chest?
08.05.2020 20:43 # 11
boruc
In my mind comes the equipment under the hood, which is behind the instrument panel.
For example, a throat butterfly, there is a mechanism to which the gas wire is connected, as if in those regions.
I didn't know, my head is so complicated
08.05.2020 20:43 # 12
boruc
Anyone who has no idea this voice started to get angry
08.05.2020 20:43 # 13
bjkamil
teacher, can I record the sound here? I have a similar voice in my car but it only happens when I get up at low speed in 1st gear.
08.05.2020 20:43 # 14
fatihyesilyurt
the same problem exists in my vehicle there is a whirl between 2000 rpm and 2500 rpm. the master said to drop the chest on weekdays.
08.05.2020 20:43 # 15
Karacocuk24
It took me 2 months, it was gone when the weather was ice, now it is very rare, sometimes it is peaking at idle.
08.05.2020 20:43 # 16
boruc
[QUOTE = fatihyeşilyurt] same problem is in my vehicle there is a whirl between 2000 rpm and 2500 rpm. the master said to drop the chest on weekdays. [/ QUOTE]
If you solve the problem, I would appreciate if you inform from here
08.05.2020 20:43 # 17
fatihyesilyurt
I could not find some opportunity and go to the master, can anyone solve this problem.
08.05.2020 20:43 # 18
bjkamil
[QUOTE = fatihyeşilyurt] I could not find some opportunity and go to the master, can anyone solve this problem. [/ QUOTE]
I had my car checked over the weekend. motor ears are broken. I think there is a bidet on the bottom and on the top. I said 250 TL. He said no problem unless you take off hard.
08.05.2020 20:43 # 19
fatihyesilyurt
The sound problem in my car was for a very funny reason. The lpg hose said, the master was making a sound and hitting the chassis as he gave gas. We shorten it, fix it, it's gone. zero cost. He said how many masters I have visited, all will be removed. it would be wasted all the money.
