sound from the first starter
08.05.2020 18:50 # 1
smiley
Hello friends,
Sometimes when starting my vehicle, when removing the screw with the electric screwdriver machine, when the device is unable to remove the screw, there is a sound or a sound like that. As if something is wasting. It was a slightly different analogy, but I hope I could. Then the car runs normally on the second or third starter.
What could be the problem? My vehicle is 2001 model quicksilver.
smiley 2014-10-14 22:39:38
08.05.2020 18:50 # 2
smiley
Does anyone know
08.05.2020 18:50 # 3
popeyes
Hi Brother,
Your problem is related to the Starter engine
This noise is also caused by the gear not being able to sit in place. we can say that the starter is missing the engine.
Dirt may have entered the spring mechanism of the starter motor, or the teeth may have been peeling.
The starter motor may need to be replaced if you damaged the starter gear.
However, even if there is no damage, a mechanic should look for any damage to the surface of this gear.
08.05.2020 18:50 # 4
smiley
If there are many comments, I would expect different comments. smiley 2014-10-16 20:49:07
08.05.2020 18:50 # 5
omera
What a coincidence, the same thing happened to me last night. I pressed the starter, a strange sound. He recovered to the second one, but after he worked, he had a whispering sound like not leaving gear for 1 second.
I asked friends at work today, they said they started to miss anthem.
08.05.2020 18:50 # 6
smiley
I looked at the prices of the starter engine from the internet about 400 TL. When it comes to workmanship, it will reach 500-550 TL. It makes more sense to use it. I wonder if he leaves the road ahead smiley 2014-10-16 20:49:52
