sound from the engine?
08.05.2020 15:10 # 1
werty
greetings
friends, when I walk into the parking lot of a shopping center, I realized that there is a sound coming from the engine, click, click, click. But when I linger for about 1 hour and started the car again, it was cut, then it made the road again. When entering the parking lot of the mall, the temperature indicator was a little over 90 (normally it always stops between 90 and 70).
1.6 16V gasoline 206 quicksilver car no gas
thank you for your attention
respects
08.05.2020 15:10 # 2
peugeotefe
This sound may be because the vehicle does not fill the cups. How many thousandths of oil was last serviced and how many thousandths of the vehicle is now
08.05.2020 15:10 # 3
furkan
turn up the sound of the tape
08.05.2020 15:10 # 4
werty
My 100,000 km car was last 1000 km before the oil maintenance.
08.05.2020 15:10 # 5
peugeotefe
Which brand of oil you use, what is the brand and it would be better if you write 10/40 or 15/40
08.05.2020 15:10 # 6
werty
I put it with mobile 1 0-40 boron power.
08.05.2020 15:10 # 7
peugeotefe
I understand that if you would prefer another brand of engine oil. If the sound you mentioned increases when it gives gas, it probably doesn't fill the thrust if it cuts at high speed.
08.05.2020 15:10 # 8
volkan22
When the brother starts the car in the morning, the engine comes out and the noise comes from the engine.
08.05.2020 15:10 # 9
peugeotefe
What is your vehicle, how many engine diesel fuel?
08.05.2020 15:10 # 10
werty
Master, what should we do? Do you mind if I use it until the next oil change.
08.05.2020 15:10 # 11
volkan22
my car 306 2.0 16v gasoline
I wouldn't do it like this before
I run it in the morning, the sound is clattering from the machine.
I'm driving a little bit warming up sound goes: S but not a normal sound: S
and the temperature of the car is based on 100s.
The vehicle did not subtract water, and the water started to subtract: S
08.05.2020 15:10 # 12
peugeotefe
It is not possible to say anything clearly before seeing it, but probably there may be a problem with the cylinder head.
08.05.2020 15:10 # 13
werty
08.05.2020 15:10 # 14
volkan22
walla temperature is based on 100 and something would have been dictated.
Even though I did not step in the car, I stopped talking to the friend if we were talking through the window.
the car is so hot he said: S
2 days ago, water started to subtract. Half a liter of water was extracted.
08.05.2020 15:10 # 15
volkan22
werty sister clicks in your car like yours: S
and he did it for up to 2 days
from the back of your machine where the sound is right,
As I said, the vehicle would not go over 90, now it is based on 100s: S
Does your car reduce water?
08.05.2020 15:10 # 16
peugeotefe
[QUOTE = werty] master, what should we do? Do you mind if I use it until the next oil change ... what do you say it will push in one? [/ QUOTE]
It is useful to drain the oil and replace it with castrol 10/40 and a total of 10/40 without causing any further damage.
08.05.2020 15:10 # 17
werty
I did not look at the water of walla openly, but it was just like the sound coming from the engine cover, but I did not have the opportunity to look at it at that moment. but then when he got off the road everything was back to normal. Then I stopped again on the road, I looked at the hood, the sound was cut off
08.05.2020 15:10 # 18
volkan22
You are right, efe brother, it must be from him
I just grabbed the oil of the car
In the car with little oil: S I think they put a little in service: S
unfortunately, the level of oil in the oil bar is below the line: S
Is 2.0 set at 16 v 10/40?
08.05.2020 15:10 # 19
peugeotefe
[QUOTE = volkan22] werty sister clicks on your car like yours: S
The problem in your vehicle may not be the same as the problem in our friend's vehicle. Since there is a 306s 2000 engine, the cylinder head is damaged in the slightest temperature and the vehicle should be looked after.
08.05.2020 15:10 # 20
peugeotefe
[QUOTE = volkan22] efe brother is right you must be from him
Yes, add 10/40 oil or make 4 liters and change it.
Page : / 2
