Sound from the engine
08.05.2020 20:26 # 1
Snrzrl
Good morning festivities, the engine and apricot of the 307 vehicle started to sound like a sewing zone from there.
08.05.2020 20:26 # 2
whisky
I think if you can make a video that can be understood, you can benefit more.
08.05.2020 20:26 # 3
Snrzrl
I can't shoot right now I can shoot it in the morning, hopefully the problem is not big
08.05.2020 20:26 # 4
Snrzrl
Today I changed the tension wedge, the sound did not stop, the master said it might be from the hoop, now it is the hoop
08.05.2020 20:26 # 5
mehmetkaya
The belt may have been stretched, a similar problem had happened to me. The problem was solved when a last master thought of changing the strap. Over time, the strap can stretch.
08.05.2020 20:26 # 6
ruhela
The hoop of the motor pulley is originally made of plastic in the middle, it is impossible for you to see the plastic and iron hitting each other. I had this incident 3 times, we changed the tensioner, it was making noise every time and it started coming back 1 week later. if it sounds like a bird's sound, the hoop starts to sound like a sewing machine.
08.05.2020 20:26 # 7
Snrzrl
Today I changed the pulley, cut the sound, I went 20 im road, this time the sound of the bird started to sound, I went to the master again, the tensioner wedge said. Actually, I thought that I will change the tax in the future when the belt will be stretched. Snrzrl 2017-06-28 19:40:54
08.05.2020 20:26 # 8
Snrzrl
The sound of the first sewing machine was like the sound of the sewing machine. I asked at least 6 masters. All of them said the tensioner. The sound was not interrupted.
08.05.2020 20:26 # 9
Snrzrl
Yes, we came to the end of the road today, I changed the belt and tension wedge. There was no sound left. It was a little costly to me.
