SOUND FROM THE ENGINE
08.05.2020 19:29 # 1
emrah8080
GOOD DAY FRIENDS. I NEED YOUR HELP ON A SUBJECT. TODAY STARTED TO COME FROM MY CAR'S ENGINE. CAN THERE BE HELP IF YOU HAVE EXPERIENCED OR KNOWLEDGE ABOUT IT? SOUND COMING IN ROLLANT SOUND.
08.05.2020 19:29 # 2
emrah8080
IT MAKES A VIBRATION WHEN GAS GAS TO THE CAR.
08.05.2020 19:29 # 3
talip206
It can do because of the exhaust system. It may have burst, connections that hold the exhaust loose, or the final muffler may be full. Hold the tip of the exhaust and shake it
08.05.2020 19:29 # 4
emrah8080
I CHANGED THE SILENCER NEW. A SOUND IS COMING TO THE HEAVY DUTY OF THE OIL COVER.
08.05.2020 19:29 # 5
emrah8080
https://youtu.be/XwF1tlMZ9fM YOU CAN HEAR THE SOUND FROM THIS LINK. I RECORDED THE VIDEO AND ATTENDED YOUTUBE.
08.05.2020 19:29 # 6
talip206
It sounds like it comes from where the straps are. That's the scattered ball sound. crank pulley, timing or recirculation, I think show as soon as possible. If the timing breaks, it causes a lot of trouble.
08.05.2020 19:29 # 7
tarantula_tr
Hodja, if you show it to a master, it would be a good problem if your friend breaks the timing, as your friend says.
08.05.2020 19:29 # 8
emrah8080
I will leave tomorrow, God willing.
08.05.2020 19:29 # 9
emrah8080
THANKS FOR YOUR HELP. SOURCE OF THE SOUND TRIGER AS OUT AS YOU SAY.
08.05.2020 19:29 # 10
ismailkaya
Like an alternator, it can make me sound from the tensioner bearing of the apricot.
08.05.2020 19:29 # 11
raconcu
İsmailkaya said there was a sound like this, I showed the master a sound like a blowing sound coming from the alternator belt. When I pressed the gas, the sound was increasing. Use the master, we will replace it in the next maintenance, he said complete, so I use it.
