sound from the engine
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models
08.05.2020 17:36 # 1
hayatiozturk66
friends, I shared this problem before & nbsp; but I couldn't find the solution :( I went to 5 masters & nbsp; they said they were seperate bisey; & nbsp; room it & nbsp; even though what the masters say & nbsp; the car clearly determines, the fuel is super good, good smoke, no oil reduction & nbsp; apricot was 60 thousand km, various maintenance & nbsp; disconnected engine They said it was very expensive to repair 4000 5000 euro & nbsp; I decided it too but my last Turk master & nbsp; it seems like no big problem but I can not say for sure & nbsp; it is best to spend a lot of money until I find the problem and get out of the room :)) ) & nbsp; if my problem is a little bisey & nbsp; or if it is 500 - 1000 euro bison, but nobody knows the problem, now I don't know what to do in the little bisey & nbsp; motor atilmazki & nbsp; i'm waiting for help from the engine master friends & nbsp; I took a video link for the sound please & nbsp; I added a link below & nbsp;
08.05.2020 17:36 # 2
Zek-i
I am someone who follows your site as an incoming.
Thank God I have not had a problem with my vehicle so far.
I write this because it is 3-4 more times and it catches my attention.
When someone has a problem with your vehicle opens a topic. So someone is sharing your problem here.
Nobody writes good or bad right or wrong. > This is not the purpose of the forum.
If I wrote a wrong word you can correct it.
There is something to be written for 7-8 hours. for example
Post Time: & nbsp; < / span> 7 Hours 24 Minutes & nbsp; before 06:36
Zek-i 2013-05-20 13:07:37
08.05.2020 17:36 # 3
Bugra
Get well soon. knowledgeable friends will help.
08.05.2020 17:36 # 4
Bugra
[QUOTE = Zek-i] I am someone who follows your site as an incoming.Thanks, I have not had a problem in my car until now.I am writing this because it is 4-4 more times and it attracted my attention. So someone is sharing the problem here. Nobody writes good or bad right or wrong. This is not the purpose of the forum. If I wrote a wrong word, you can correct it. There is a subject that needs to be written for 7-8 hours. like: Submission Time: 7 Hours 24 Minutes ago 06:36 [/ QUOTE] Thank you for your notice. There is something in this forum, everyone in this forum, including its manager, has a job they do outside of this forum. Nobody is waiting on the watch so I can reply to the forum in case of a subject, so that it is not possible to mislead the victim in such matters. therefore, forums that do not have the correct information read the subject but do not reply so that there is no misleading. For example, I do not have a certificate or mastery about cars. but in general I know most things or things that happen ... I have no idea about the subject of this friend. I didn't see anything on my head and I did not hear it. What should I write about this person's subject now? I write `` get well soon, knowledgeable friends will help. '' to ensure that the person in this situation constantly updates the subject and attracts the attention of knowledgeable friends.
08.05.2020 17:36 # 5
Zek-i
[QUOTE = bugrature] [QUOTE = Zek-i] I am someone who follows your site as a visitor. Thank you that I have not had a problem with my car until now. I am writing this because there is a problem with someone's car on your site. Nobody writes on the subject. So someone is sharing the problem. Nobody writes good or bad right or wrong. This is not the purpose of the forum. If I wrote a wrong word, you can correct it. There is a subject that needs to be written for 7-8 hours. like: Submission Time: 7 Hours 24 Minutes ago 06:36 [/ QUOTE] Thank you for your notice. There is something in this forum, everyone in this forum, including its manager, has a job they do outside of this forum. Nobody is waiting on the watch so I can reply to the forum in case of a subject, so that it is not possible to mislead the victim in such matters. therefore, forums that do not have the correct information read the subject but do not reply so that there is no misleading. For example, I do not have a certificate or mastery about cars. but in general I know most things or things that happen ... I have no idea about the subject of this friend. I didn't see anything on my head and I did not hear it. What should I write about this person's subject now? I write `` get well soon, knowledgeable friends will help. '' this is to ensure that the person in this situation constantly updates the subject and attracts the attention of knowledgeable friends. Regards .. [/ QUOTE] I agree with what you say. But this is 3 or 4 topics that I noticed. There are 16-17 people on the site right now. I am a working person. It is OK if the moderators follow the topics. Then it is wrong that they should not follow and write about it. Maybe you will say that the moderator does not have this information. You should not make any moderator. Let me not misunderstand my friends. I want to explain here is a different situation. I want to explain that the moderator is knowledgeable and knowledgeable about the topics.
08.05.2020 17:36 # 6
How many kilometers is the vehicle? How many fat is there? Also, is the engine malfunction light on?
08.05.2020 17:36 # 7
ismailkaya
your engine is super running yuotub taki vide if your car is also your car model brand fuel gasoline diesel what is maintenance how was done you need to write all of them let's comment
08.05.2020 17:36 # 8
ismailkaya
guess on the steering pump belt and disc
08.05.2020 17:36 # 9
cerci07
vitally, your masters have said the same thing as what I have said above, the sound will increase over time, maybe it will be easier to find the failure in the future, it may be easier to find the failure & nbsp;
but if you say that I will cut this sound, replace the engine, cheaper the engine, cheaper it will come cheaper.
08.05.2020 17:36 # 10
hayatiozturk66
the car I bought at 183 .000 thousand & nbsp; 5 & nbsp; 5 40 put it later I realized that & nbsp; not branded Because they are lied, I recommend total & nbsp; 5w 30 c2 & nbsp; I put it in & nbsp; and I added a bidet sound cutter & nbsp; but there was no reduction :( meanwhile the car diesel & nbsp; 607 & nbsp; 2.2 hdi 136 & nbsp; play
08.05.2020 17:36 # 11
hayatiozturk66
[QUOTE = koliva] How many km is the vehicle? How many fat is there? Is the engine malfunction light on?
the man I bought at 183 .000 thousand & nbsp; & nbsp; 5 40 put it later I realized that & nbsp; not branded & nbsp; labo & nbsp; i think the name is & nbsp; i have changed myself because the time has come now the oil is car fab & nbsp; 5 & nbsp; they advise that I put it & nbsp; and I added a bidet sounder & nbsp; but there was no decrease :( by the way, the car diesel & nbsp; 607 & nbsp; 2.2 hdi 136 & nbsp; burnt engine failure light blah blah & nbsp; first cold starter operation & nbsp; super & nbsp; no oil reduction no black smoke & nbsp; only sound & nbsp;
08.05.2020 17:36 # 12
hayatiozturk66
[QUOTE] cheaper income come easy
[/ QUOTE] they said it before they cut it, I decided it to me, I found it at 130 thousand 1400 euro or 3 months guaranteed, this last oren turk master 180 euro I put it on my hand said & nbsp; of course prepaid & nbsp; but & nbsp; it looks like there is nothing big but I have to be sure I need to be searched & nbsp; I don't want to be embarrassed & nbsp; he said take the engine because of it & nbsp; I don't know, I haven't decided yet, brother
08.05.2020 17:36 # 13
hayatiozturk66
[QUOTE = ismailkaya] your engine is running super & nbsp; yuotub taki vide is your vehicle and the model of the vehicle is branded petrol gasoline & nbsp; what is maintenance how & nbsp; you should write all of them so let us comment
& nbsp;
[/ QUOTE] yes my car video water brother maintenance every 20000 thousand & nbsp; the man who made a zero is a 1st hand old man & nbsp; there is a thing in 122 thousand & nbsp; valve tappets and & nbsp; oil pump I think it has changed & nbsp; the oil pump is broken, it was damaged when the oil did not come out & nbsp;
08.05.2020 17:36 # 14
hayatiozturk66
tirger apricot rulmon & nbsp; could make such a full sound & nbsp; room was said & nbsp; There was also one who called the eccentric chain, I saw it & nbsp; not loosely & nbsp; I guess it is not, I wonder if it can be made from the flywheel ?? no sound when running on the bus & nbsp; it looks like a bit of engine jerking & nbsp; or it seems to me but & nbsp; there is no sound at idle & nbsp; I do not know why it is going to go up after 2000 or engine noise is increased. I would be glad if my masters help you as much as you can.
08.05.2020 17:36 # 15
hayatiozturk66
The brother said he might have been out of bed, but I asked the master if he said the room would damage the crankshaft now, I don't know if the pistons would not work well and the power would decrease. ?
08.05.2020 17:36 # 16
hayatiozturk66
friends & nbsp; no idea the last one & nbsp; i went to peugeot garag i know a 30 year biker man & nbsp; i saw 5 master i saw two valve pushers say two two crankshaft i said man just laughed & said nbsp; they said maniacmi said very guveniyo & nbsp; listened to the sound & nbsp; they said they were already coming from other masters by tirger apricot & nbsp; said from there, this sound is not the engine sound said Now I don't have time to put some time to the cake. the problem is cozulurse I write it anyway, if those who have ideas help, I would appreciate everyone good day
