sound from the engine
08.05.2020 17:22 # 1
atillaustun
mrbalar & nbsp; After I checked my car, I noticed that there was a noise coming from the engine, and when I first noticed the factor I thought came from the belts or the belt pulleys, I realized that the sound came when my foot was pressed in the clutch. When I release the clutch, the sound is cut off, as if there is a ball of noise from the gearbox, I wonder if the car has just changed the old owner, but did anyone have the same problem?
08.05.2020 17:22 # 2
Serkan
Just like a voice teacher is buzzing, the pressure comes from the pad.
08.05.2020 17:22 # 3
sezar206
I have the opposite situation. When the pressure is cut off, the sound is giggling when I leave it :) I showed it to the master, give the ball in the transmission, he said it is making the sound.
08.05.2020 17:22 # 4
atillaustun
Did the price set mean that the print set would have to mingle?
08.05.2020 17:22 # 5
Bugra
Professor priorities When you enter the profile from the member control panel, there is a section called signature. If you write brand model version information of your vehicle. I know what your vehicle is and we will say something accordingly.
I have no idea what the problem is. Our site sponsor has a clutch set campaign. flashes new at the top of the forum page. respect for the ...
08.05.2020 17:22 # 6
streetglow87_26
I have the same voice, but vice versa. When I press the clutch, there is no sound.
25,000 km before the press brake
08.05.2020 17:22 # 7
[QUOTE = streetglow87_26] I have the same sound, but vice versa. When I press the clutter, there is no sound when I pull my foot. Has the pressure been changed to the lining or as a set?
08.05.2020 17:22 # 8
streetglow87_26
I know it changed as a set
08.05.2020 17:22 # 9
istanbullu_3886
I think your problem is fork
08.05.2020 17:22 # 10
streetglow87_26
When I say fork, I don't have much technical issue
08.05.2020 17:22 # 11
istanbullu_3886
When the clutch pedal is pressed, the part we call the fork is pulled and the pressure is separated from the flywheel.
08.05.2020 17:22 # 12
streetglow87_26
I understand then your transmission will land again
08.05.2020 17:22 # 13
mistik
I had the voice coming when I left the clutch. the pressure is interrupted .. I went to the service clutch set will change, he said to me (550tl)
08.05.2020 17:22 # 14
atillaustun
Thanks guys, let me see what I will see this week for information: D
