Sound from the engine?
08.05.2020 20:51 # 1
omernc
[TUBE] e5ag07htbwk [/ TUBE]
When the engine is idling, it sometimes sounds loudly. Does anyone have the idea of being understood more clearly at the end of the video?
[TUBE] vtzpg8yıy34 [/ TUBE]
omernc 2018-04-27 09:45:31
08.05.2020 20:51 # 2
boruc
Does the sound continue when you press the clutch?
Sometimes I hear a little noise. It is interrupted by pressing and releasing the clutch fully.
They say they do it from the prisdirek ball, but I don't know exactly.
Fitters 2018-04-27 13:13:51
08.05.2020 20:51 # 3
omernc
I didn't pay attention like that, but it doesn't come when I am insulted
08.05.2020 20:51 # 4
breakbeat
The vehicle's engine is too low, could your sheet pan cover guard come into contact with the engine?
There is also something like an air blowing channel next to the place where the gear is, perforated, what is its name? They are not in my vehicle
breakbeat 2018-04-27 18:52:10
08.05.2020 20:51 # 5
omernc
I press the clutch and pull while the sound is not interrupted. I think it has nothing to do with the clutch. Sometimes it sounds
08.05.2020 20:51 # 6
omernc
I guess there is no character protection.
I do not know the name of the ventilation holes
08.05.2020 20:51 # 7
okaNStarss
If this sound does not do after the vehicle warms, it does not, if it cuts, there are some tightening places on the injectors. Show it to a master. It takes 15 minutes.
08.05.2020 20:51 # 8
omernc
Doesn't do after warming up.
Let me look at the injectors
omernc 2018-04-28 10:30:29
08.05.2020 20:51 # 9
pusutr
check the tensioner roller. I think there is excessive oscillation.
08.05.2020 20:51 # 10
omernc
Smile where is the tensioner bearing
Can i fix it
08.05.2020 20:51 # 11
omernc
Idle does not when he is 9, when he presses the gas and brings it to 10.
08.05.2020 20:51 # 12
breakbeat
Have a look at the alternator bearing. It is a piece attached to the v-belt. You can even open the hood and see for yourself
08.05.2020 20:51 # 13
omernc
The alter belt, alternator belt lock, and the crank reader after the sensor change, the sound is reduced. I do not know if the sound continues on the proving days. There is a sound now and then.
He improved after 2 places and 1 real master. I do not know if there will be advertisements, but I would recommend aktaş oto as a result.
08.05.2020 20:51 # 14
CavitK
Selam aleykum today, an incident came to me, when the vehicle was in 1 gear, the floor came out from the car, and when the car stopped, when I started again, when I pressed it, the station is stationary, and when I press it again, the sound is cut off and the gear shuts down when you press the foot, and what is the reason why your feet are constantly on the floor when you pull it off from the drain.
