Sound from the Door
08.05.2020 19:27 # 1
38HT299
hi friends my 206 5 door bi vehicle front and back doors each have 2 speakers
his voice is satisfactory, but when I turn on the bass, there is an incredible plastic knock sound (like a sizzle) through the doors.
08.05.2020 19:27 # 2
talip206
The plastic clips of the door pandezots were broken. You can buy and install new clips. You can also make a small insulation while removing it. You can install soft adhesive tapes where the door edges touch the metal part and cut the vibration.
08.05.2020 19:27 # 3
GokhaN
our cars are not coming to bass too much.
08.05.2020 19:27 # 4
38HT299
I bought new speakers to prevents back 14 cm, 17 cm I do not remember the brand sponge absorbing it'll make me http://i.hizliresim.com/b03rjl.jpg place in the picture sponge if I olurmu superior shortage?
08.05.2020 19:27 # 5
Mesut48
the box of the front door speaker is riveted, refresh them,
I don't know the back doors.
08.05.2020 19:27 # 6
samet206
You have just bought the speakers, you do not realize that when removing and installing the floors, either missing the clips or some of the clips were broken during the installation. Apart from that, it shouldn't make plastic sound because I recently renewed the door speakers without isolation, even without replacing the old clips. The bass you can get from the door speakers is obvious, there is not enough bass to enrich the flooring. This may happen if you have not tightened the screws firmly because the screwing places of the new generation speakers are U-shaped and if you do not install them with the small apparatuses that come out of them, they will remain loose as soon as you pass the double-sided tape around the speaker, then you will act as a gasket and then tighten the screws, it will be more firm and fully fixed.
