Sound from the clutch
08.05.2020 20:49 # 1
x571
After the vehicle moved, we stopped at the red light. We put the gear in neutral. We pulled our foot off the clutch. It sounds like a lousy, lousy voice. when you press the clutch, the sound goes away. the sound comes a km after the car moves. There is no sound when going on the road, there is no sound when you take your foot off the gas, there is no sound when you get up at the 1st gear.
what is this problem? how to solve it?
08.05.2020 20:49 # 2
GokhaN
either this sound can be from more than one thing, it may be from the engine ear, it may be from the pulley-belt, it is reflected in other things, the clutch is finished, it may be from it clear power
08.05.2020 20:49 # 3
x571
[QUOTE = GökhaN] either this sound can be from more than one motor can be from the ear, may be from the pulley-belt, it is reflected in other things, the clutch is over, it can be clear.
The clutch has changed to 17 thousand km. Can I understand by opening the hood or is it helpful to upload videos here?
08.05.2020 20:49 # 4
It may be as if the clutch bearing, but it may be necessary to have the clutch fork and wire checked, as if my teacher is not leaving it completely, or if the bearing is broken, this sound may come from it. If you upload youtube for the video, we can put the link in the forum
08.05.2020 20:49 # 5
x571
[QUOTE = sonerkyl] like a clutch bearing, but it may be necessary to have the clutch fork and wire checked, as if my teacher is not releasing it, or if the bearing is defective, this sound may come from it. If you upload youtube for the video, we can put the link in the forum hojam. [/ QUOTE]
I added a video. maybe it gives an idea.
[TUBE] 0ankchbg9rs [/ TUBE]
08.05.2020 20:49 # 6
x571
the subject is up to date.
08.05.2020 20:49 # 7
Honestly, I watched the video 5-6 times, honestly, but it is not fully understood. Frankly i couldn't understand Stern Smile
08.05.2020 20:49 # 8
x571
[QUOTE = sonerkyl] I have watched the video 5-6 times, honestly, but it is not clear. Frankly i couldn't understand Stern Smile [/ QUOTE]
If we assume that the clutch bearing is from the clutch fork, are these serious problems? The bearing only has the opinion that it makes sound on the Internet. I don't know about the fork. If it rests on the 147bin dial, then I will replace the clutch wire. For example, he was not making any sound today.
08.05.2020 20:49 # 9
boruc
I have the same situation for a long time.
I can hear the sound you said from the video because I know Smile
An audio twill that continues in a click-by-click format Smile
When you press and release the clutch, the sound stops or the tone should change.
As I said, I have had this voice for a long time. It doesn't cause any problems.
He talked about a piece called Prizdirek ball master, but I did not think of it because it did not cause any problems.
08.05.2020 20:49 # 10
senalcay
Clutch bearing is broken, my friend. I also have 206. My previous car was also born.
Do not worry, it does not cause any malfunction but do not worry. When replacing the clutch lining, they just changed the pad and said the bearing was good. Actually, the bearing should be renewed together with the pad, even if it is in good condition. - Transmission is not worth downloading.
08.05.2020 20:49 # 11
x571
[QUOTE = boruc] I have the same situation for a long time.
Exactly :) You are pressing and releasing the sound. some days i don't hear any sound. Clutch set changed 20,000 km ago. probably not changed then. Let's break it again, plug it in again and get money.
08.05.2020 20:49 # 12
boruc
[QUOTE = x571] [QUOTE = loan] I have been in the same situation for a long time.
My 40,000 km has changed pressure. The sound has been around for a long time, let's see where it goes Smile
