Sound from the clutch?
08.05.2020 19:21 # 1
DarkSilver
Hello friends,
Actually, there are many issues related to this topic, but I opened a new topic because I could not find a complete answer to my question.
There is a sound coming from the clutch of my vehicle for 1 week. The sound is like `` knock it off '', like a vibration sound of a metal part.It generally comes down while changing gears at low revs, most of the time it comes when I take my foot slowly from the pedal. I guess I can handle all of them when it comes to changing the pressure of the pad, but I have filled this limit when I say the timing set, the regulator.
08.05.2020 19:21 # 2
emre41
Hello, when the socket hanger bearing presses the clutch, it will also sound when you release it. Do not be fooled.
08.05.2020 19:21 # 3
DarkSilver
[QUOTE = emre41] Hello, when the pole hanger bearing presses the clutch, it also sounds when you release it. Do not be fooled. [/ QUOTE]
It sounds exactly like that. When I press the clutch and change the gear, I start to pull my foot, there is no sound.
08.05.2020 19:21 # 4
emre41
If the socket had pole hanger bearings, it would make a noise when going in gear. Clutch bearing of the problem. The pressure changes when replacing the pads. Don't mind yourself. emre41 2015-07-08 16:29:36
08.05.2020 19:21 # 5
DarkSilver
[QUOTE = emre41] If the socket had direct hanger bearings, it would make a noise when going in gear. Clutch bearing of the problem. The pressure changes when replacing the pads. Don't mind yourself. [/ QUOTE]
Thanks, brother. If it is just a sound, it's okay.
08.05.2020 19:21 # 6
DarkSilver
Yes, we said nothing, but today I entered the garage and approached the clutch. Cry If I had a loyalty, he did not empty on the way, at least thank him. In no way does it separate the pressure. The pedal doesn't come back. I hope the industrial road has appeared with the hammer.
Be you, take it to a service without interrupting in such sounds.
08.05.2020 19:21 # 7
I hope, my teacher .. I hope it will not cost much. Do not forget to add the hammer to the service while taking out insurance, they get a difference of 30-40 TL. It is better than giving 150-200 TL to Çakici.
08.05.2020 19:21 # 8
DarkSilver
Thank you very much. I trust the hammer of the casco. A great possibility has been added to the policy.
08.05.2020 19:21 # 9
If there is a motor vehicle, there is no problem.
