sound from the brake
08.05.2020 15:13 # 1
cakici9843
When friends press the brake, the brake sounds. sounds like it is lean. does this mean that the brake is old or does the brake be intact? What do you have to wear this for?
08.05.2020 15:13 # 2
cakici9843
current friends
08.05.2020 15:13 # 3
106_arts
we need to tire the pads are over.
08.05.2020 15:13 # 4
Serhun
If the disc is a brake system, it can be checked whether the brake pads are finished by removing only the rim or by looking at it without removing the rim. Even if the pad does not run out, if you encounter the problem of making noise, dust dirt, etc., or the pad is making noise due to hardening. You can clean with lining spray for dust dirt etc. In fact, during the cleaning process, the surface, which is polished with sandpaper, must be cleaned and matted. If there is hardening, it should replace the pad, the hard pad increases braking distance and your discs wear out more quickly.
In the rear or drum type brake, it is not possible to see the situation without dismantling the tire and drum, other steps are done in the same way as the disk type.
In the vehicle with the rear drum, the sign of ending appears as the hand brake is holding it up or not.
In general, the front pads are finished at 20 000 km and the rear ends at 80-100 thousand kilometers, depending on the style of use in vehicles with front outer rear drum. The front rear disc system ends before the front lining
Serhan 2011-04-02 10:40:40
08.05.2020 15:13 # 5
cakici9843
[QUOTE = Serhun] If the disc brake system is used, it can be checked whether the brake pads are finished by just removing the rim or looking without removing the rim. Even if the pad does not run out, if you encounter the problem of making noise, dust dirt, etc., or the pad is making noise due to hardening. You can clean with lining spray for dust dirt etc. In fact, during the cleaning process, the surface, which is polished with sandpaper, must be cleaned and matted. If there is hardening, it should replace the pad, the hard pad increases braking distance and your discs wear out more quickly.
thank you serhun. Let's make an application with lining cleaner. Let's see if it's dirt? now we will show the master ...
