Sound from the bottom back
08.05.2020 20:53 # 1
x571
Hi
while the vehicle is walking, there is a cracking sound from the bottom rear wheels. it sounds like a metal, like a metal. just released. not doing all the time. Generally, the vehicle leaves the garden in the first movement in the morning, while doing full right or left left maneuver. why can this happen? how can it be solved? Where should I check?
08.05.2020 20:53 # 2
boruc
Could it be torsion?
08.05.2020 20:53 # 3
x571
[QUOTE = boruc] Could it be torsion? [/ QUOTE]
I do not know that . how does he control it? when I turn to the right, I usually hear sometimes it does not come sometimes
08.05.2020 20:53 # 4
Check the exhaust wedges, brother.
08.05.2020 20:53 # 5
x571
[QUOTE = sonerkyl] Check the exhaust wedges also bro. [/ QUOTE]
When I looked under the vehicle, I saw an oil leak in the left rear shock absorber, it had dust on it, but can wet do this problem? How do we control the exhaust wedges?
08.05.2020 20:53 # 6
GokhaN
metal sound usually comes from torsion. You can look at the exhaust control by shaking it.
08.05.2020 20:53 # 7
x571
[QUOTE = GökhaN] metal sound usually comes from torsion. You can look at the exhaust control by shaking it.
How do I know if there is a problem with torsion? Is there an inspection method? jacking up or something? or otherwise
08.05.2020 20:53 # 8
aliyasin
As you said, there is a rotten sound that does not always come, usually when maneuvering. If you find out why I would like you to share.
08.05.2020 20:53 # 9
x571
[QUOTE = aliyasin] As you said, there is a crack sound that does not always come, usually when maneuvering. If you find out why I would like you to share. [/ QUOTE]
I couldnt find it. It went by itself. I did not take it to the repairman, they will spend money and pay for it.
