Sound from the 407 1.6 hdi engine ...
08.05.2020 19:53 # 1
407 ERHAN
Hello, when you idle from the top of the engine or take your foot off the gas and go at low speed on its own, there is a sound like hissing, do you have any information, friends, thank you ...
08.05.2020 19:53 # 2
Bha41
There was a slippery sound from me too. I think yours is a different voice
08.05.2020 19:53 # 3
407 ERHAN
Yes, there is a hissing sound coming from the engine, like air sound, hissing hissing ...
08.05.2020 19:53 # 4
xmen
[QUOTE = 407 ERHAN]
Yes, there is a hissing sound coming from the engine, like air, hissing hissing hissing [[QUOTE]
Sir, the injectors make the sound you call. There are copper scales called Oring, you need to change them, it is not very expensive.
08.05.2020 19:53 # 5
407 ERHAN
Xmen brother, thank you very much, I hope it is as simple as you say, hope it won't work on my head, thank you very much, have a nice day ...
08.05.2020 19:53 # 6
xmen
[QUOTE = 407 ERHAN]
Xmen brother, thank you very much, I hope it is as simple as you say, hope it won't work for me, thank you very much, have a nice day ... [/ QUOTE]
You are welcome, I hope you can handle it smoothly, only the workmanship can hold a little bit. Otherwise, the orings are very cheap, and if you share the result from here, it will be a guide for the friends that happen to you.
08.05.2020 19:53 # 7
407 ERHAN
I am going to industry today, of course I will write the result, thank you very much for your interest and interest, have a nice day ...
08.05.2020 19:53 # 8
407 ERHAN
Friends, the sound from the engine was resolved, as my friend said, the sound of the injector was coming from the flake washer, he was making a hissing sound because he was leaking, he was only in an injector, when the master poured the water, he sprayed water from the first injector, he said, let's change all four, he kept a total of 100 rubles, for your information friends, I also thank my xmen friend for informing me in advance, have a nice day ...
