sound from right wheel on left turn |
| 08.05.2020 20:21 | # 1 |
| 08.05.2020 20:21 | # 2 |
My brother checked the torsion bushings and shock absorbers on the axle. I came to my head with a robust master. I did not change the torsion and shock absorbers and put the axle on the lathe at a cost of around 1000 TL.
| 08.05.2020 20:21 | # 3 |
sonerkyl |
if it is on the front wheel there is a problem with the front swing - tie rod end and z-rod.
| 08.05.2020 20:21 | # 4 |
ball joint tightening bolt loosened. We renewed the bolt nut, it was resolved. 20 tl. |
| 08.05.2020 20:21 | # 5 |
Hello friends, in my car, there are 1-2 people in the car, especially when the left turns (except me).
| 08.05.2020 20:21 | # 6 |
sonerkyl |
[QUOTE = 01DNA76] hello guys in my car too when you turn left, especially when there are 1-2 people in the car (except me) what do you think sounds are from the right rear wheel? [/ QUOTE] It may be torsion.
| 08.05.2020 20:21 | # 7 |
Master tornation ball, buy it, he said, I bought it for 45 TL. Let's go to the master at the appropriate time. He said how much he will want, he will go to the lathe, he will join the piece.
| 08.05.2020 20:21 | # 8 |
[QUOTE = senalcay] ball joint tightening bolt loosened. [/ QUOTE] be careful that the bolt you install is not fully passed, then the ball joint will come out.
