Sound from Peugeot 206 engine
08.05.2020 21:27 # 1
bektasekice3591
Friends I write the subject a little long. The event started like my car peugeot 206 1.4 hdi
I did not realize that there was a water leak in my vehicle, I got out of the way, I came to the top, I took it to the right, I added water and continued to the industry. The master said there was no problem, he took care of the leak and put more antifreeze. Then the car started to slip off, a small pipe hit the floor, the room was replaced. Now, when I open the water door, it sounds as if the cola water opens, the pressure is getting too low, the water is constantly decreasing, but I cannot find a leak. When driving the car, sometimes it doesn't sound like a thin voice because we clicked from the engine. There is nothing wrong with the towing of the vehicle, everything is normal. Previously
Well, I've met my case. I said to the masters, can there be gaskets?
Thank you for the wars now .. Shocked
08.05.2020 21:27 # 2
Get the best compression test, brother, fat reduction is a problem. may escape from valves. water may leak into the oil. etc. Because it is a closed circuit system when it sounds normal like a coke sound. the sound may come from the bottom thrusters. Is this sound more when it is cold or hot or not at all.
08.05.2020 21:27 # 3
FatihBall
If it does not work in the cold engine, when the engine temperature reaches a certain temperature, the cylinder valves may run out of oil or water, the top cover may be cracked, if you go to a mechanic, the clear solution is, but the pressure of the radiator water indicates that the tool is healthy, making enough compression in the piston.
Do you give white smoke after 3000 rpm from the exhaust?
