Sound from pad and disc?
08.05.2020 19:23 # 1
Turgay_66
Hello friends, I changed 4 brake pads and ten discs about 300 km ago. Today, the sound of the kite started to go slowly from right to the right. He said, "What are your opinions?" :)
08.05.2020 19:23 # 2
dagdelen34
If there is no sound touching the brake while going, the disc is incompatible with the pad, when you press the brake, the sound will come in the acclimation process, but it is not normal if there is sound without interfering with the brake.
08.05.2020 19:23 # 3
Turgay_66
Hodja, I bought discs and pads according to the chassis, we checked the same, sound starts to sound when traveling at an average speed of 40 km. I couldn't make sense of the sound going fast or slowing down
08.05.2020 19:23 # 4
Hodja, I checked if there was curvature in the discs. If there is, ask for a change, no lathes or something, they say.
08.05.2020 19:23 # 5
Turgay_66
Teacher, I don't know I checked it, master, but why are the disks just new?
08.05.2020 19:23 # 6
My teacher may have a production error. It happened to me.
08.05.2020 19:23 # 7
Turgay_66
I understand, hodja, then it is not necessary to make a continuous sound? Is this sound over time, sir?
08.05.2020 19:23 # 8
sezar206
The pin is either not plugged in or is loose. Teak click die cuts when the sound is pressed. Die that pin does not move the pad in place.
08.05.2020 19:23 # 9
Turgay_66
the starter has springs hojam we checked there was no play, is there any air in the system?
08.05.2020 19:23 # 10
Turgay_66
how to change brake oil, friends?
08.05.2020 19:23 # 11
arachnid
I don't know how it all changes, but there is a white little box behind the battery and you add from there. DOT4
08.05.2020 19:23 # 12
Turgay_66
friends sound continues, sound starts to sound at 50 kmh speed when the brake touches a little bit, the sound goes out, may the system have made air?
08.05.2020 19:23 # 13
debug
The same thing exists in the vehicle, even though I do not apply the brakes while driving with 30-40, there is a high-pitched rubbing sound ... I have to open it and have it checked. When the brakes are applied, the sound comes first, and when it presses a little, it stops the sound :)
08.05.2020 19:23 # 14
burakbaykal2
Don't panic, nice people. If you replace it with the original lining, the car makes that sound at the first 300-400 km. I say very frankly until I found him. I loved the 200 lira money every time, change the pad, find no disc, change the disc to try ... After the pressure pads and brakes were in and out of the way, I also heard the speeds and responses you said. In the last change, I especially followed and followed how long it would go, and now the voice is gone. There is no curvature in the disc, there is no problem with the pads. I have 206+ but the same thing happened when I had 206 HDI and 1.6 Roland Garros before. So don't stress, because there's a breakdown.
