sound from new pads
08.05.2020 16:58 # 1
salihata
Friends & nbsp; I have a question, now when I applied the brakes for a long time, when I applied the brakes, when everyone said something like you would draw the discs finished, I took the car to a master, the master says that the pads are not finished or even zero, what kind of solution would you suggest? will this sound pass later? I did not have this sound when I first bought the car 8 months ago, I bought it for the last 3-4 months.
08.05.2020 16:58 # 2
berk2309
If the lining is attached to the lining industry, the lining has hardened due to the heating and cooling of the lining.
08.05.2020 16:58 # 3
I have that same problem. It makes sound when pressing the brakes and close to stopping. I took it to the master, but we took 1o tour that sound didn't come anyway. here's your chance. He said if he does it all the time. it happens when it's not there. I'm taking us to the US, there is not a single voice. I'm limit.
08.05.2020 16:58 # 4
dukenukem82
It was formed when excess metal was used in the mixture of the pad. Get Bosch or trw, try it. Except for the sound, it doesn't cause any trouble, the masters say. I bought a new lining, I said, "Let's eat bread in our men," I bought a brand. As the car accelerated, it was making a chirp as if it was braking all the time.
08.05.2020 16:58 # 5
bycem 2012-08-12 14:25:38
08.05.2020 16:58 # 6
sezar206
If there is any sound from the pads, take a look at the front and back. If it's done, you replace it. If it is not finished, the pad is an industry or set.
08.05.2020 16:58 # 7
sezar206
There is a sub-industry in front and behind, I have been using it for almost a year, there is no sound. But the brake quality makes a little difference, of course, it is not like the original pad.
08.05.2020 16:58 # 8
muratoner
I changed it, and since I knew these troubles, I especially had bosch.
08.05.2020 16:58 # 9
volkan22
There are 2 reasons if the launcher is new the disc is hanged or the pads you bought are a little hard ...
the master looks at you without inserting the pads fluffy, but your pads are not over yet, but does it stick to the disc fully? & nbsp;
but if you say I showed it to the master, he saw the condition of the disks & nbsp; probably the forums are important when installing the new pad.
volkan22 2012-08-12 23:57:02
