sound from left wheel
08.05.2020 17:38 # 1
emr_41_175
A few months after my friends took my car, voices started coming from the front left wheel. There was a sound in the moment of stopping when the brakes were pressed, there was a sound in the bidet, the sound like a bird whirling from the same wheel while the speed is increasing, the sound is increasing, the sound is increasing, the brakes are full, the sound is half more, the sound is even more so 87Model is not crazy when I have a sound like this in my 2004 206 They said, I changed the discs, they said they changed, I changed it too, I got rid of the sound of sound, but the bird sound still continues, I go to work by car, there is no sound in the morning, I go home in the evening.
08.05.2020 17:38 # 2
Mehmet38
The same problem started to happen to me. I think it comes from the balls. The robust preliminary organizer does this. Don't think about selling it right away.
08.05.2020 17:38 # 3
vbmaster
Do not take the ball into service. You go buy it from the gourmet ... they are pushing the goods. Normally, 100.000 bearings will be able to see 50 thousand without seeing.
08.05.2020 17:38 # 4
samet206
If the sound that comes from the balls sounds and the sound is cut off when a little touches the brake, then there is the sound coming from the discs and pads. You should show the master that it is likely to be from the balls as you describe it.
08.05.2020 17:38 # 5
reality59
[QUOTE = samet206] If there is a sound coming from the balls, if the sound is cut off when something touches the brake, then there is a sound coming from the disks and pads.
I am in this view. It is beneficial for a master to see the deformable master and disc.
08.05.2020 17:38 # 6
ismailkaya
lining disc-wheel bearing but not both
08.05.2020 17:38 # 7
emre_akdag
As the friends say, take the front balls yourself, go to the mechanic like that.
