sound from gear
08.05.2020 16:51 # 1
secur73
When my friends buy my car semi-automatic 307 Pden D, a voice called gub sounds colder, it becomes more pronounced when it gets cold, the sound becomes lighter when it moves, I don't feel super shifting. I want to buy ... thanks ...
08.05.2020 16:51 # 2
fTh206
You have to change the solenoids, but show it to the master. I had the same problem. When I switched from N or P to R, when you change the pounding point, the problem is gone. Do not use it.
08.05.2020 16:51 # 3
secur73
I wonder how much to change solenoids explodes ???
08.05.2020 16:51 # 4
secur73
it only happens when i get from p to r on the first departure eg 2 & nbsp; When I run to idle after running idle for minutes, the sound just feels like it is on the load ... the sound disappears thoroughly ...
08.05.2020 16:51 # 5
fTh206
[QUOTE = secur73] I wonder how changing solenoids explodes ??? [/ QUOTE] Mine had found 500 TL including labor, but the oil change was also in this price.
08.05.2020 16:51 # 6
toga406
The address on the site is two solenoids are sold on the Internet from 130 to 260 TL. What was wagner? What is the brand
08.05.2020 16:51 # 7
secur73
friends, does this have urgency ?? because I have no other problems or should I have it done immediately?
08.05.2020 16:51 # 8
fTh206
[QUOTE = secur73] friends, does this have an urgency ?? because I have no other problems or should I have it done immediately?
[/ QUOTE] When I say there is urgency, of course there is a loss of 500 kl. you may encounter it as 1.500 TL.
08.05.2020 16:51 # 9
secur73
friends for the first time I use the automatic for the first time, when we shift back, it does not do anything, so if it is a little ?? in case there is a malfunction in cellophane, all & nbsp; my voice shifts sound ???
08.05.2020 16:51 # 10
berk2309
Well, when you put the gear in reverse in all 307s, a knock knock comes in. There is no solution in it.
08.05.2020 16:51 # 11
secur73
Thank you, I was relieved, yesterday I was scared when one of your friends said you would shift the gear or something ...
08.05.2020 16:51 # 12
berk2309
No, neither is the dispensing of the gear, I have done it again. When you take the reverse gear knock back to the original pejo service, you need to do the standard single, then take it from N to N, wait for a while, discharge the pressure in the converter, then take it to R & nbsp; less knock & nbsp;
08.05.2020 16:51 # 13
fTh206
[QUOTE = berk2309] valla 307s when you put it in reverse gear, knock knob will come in the same way there is no solution in it if you change the selenod it will be the same again & nbsp; It is not even obvious now and the gear shifts have been so soft that I think it noticeably notices when it changes
08.05.2020 16:51 # 14
berk2309
I don't know it can happen in the 206s. All of the 307s have a cut out sound. & Nbsp; I have nothing to notice the solenoids I changed & nbsp;
08.05.2020 16:51 # 15
fTh206
Interesting chronic problem improved in the 307s then 206 "
