sound from gas pump
08.05.2020 16:11 # 1
zavur
friends, when the gasoline is low, when turning left and right, sometimes it stops in normal postures (no up and down), it sounds like a die, we heard that the sound is normal or not.
08.05.2020 16:11 # 2
34sea45
that sound normally comes without the first start, possibly because the gasoline is low, the pump is making noise, try not to light up as much as possible, otherwise your pump may burn
08.05.2020 16:11 # 3
zavur
hmm my buoy was just made, here are two electric & nbsp; played worked & nbsp; light full burnt out trip as soon as possible extinguisher construction & nbsp; "grin" bidet subject I opened 2 how to delete accidentally & nbsp; "Embarrassed"
08.05.2020 16:11 # 4
34sea45
in the message options on the right, you should delete it from there.
08.05.2020 16:11 # 5
zavur
message received too much & nbsp; if we don't put gasoline it will ride me & nbsp; "Embarrassed"
08.05.2020 16:11 # 6
zavur
Bidet perception after a certain liter does not perceive diolar correctness, i.e. does not go down to the bottom & nbsp;
08.05.2020 16:11 # 7
34sea45
It is true that it does not go down to the bottom, but I started to light the light.
08.05.2020 16:11 # 8
brutal
After the light burns, 40 km maximum, you can connect to the strongest place and travel in the most beautiful trunk with 5 liters of gasoline;)
08.05.2020 16:11 # 9
zavur
my mind is comfortable in that regard, I am counting on something at first, this is annoying at first but now I like it.
08.05.2020 16:11 # 10
zavur
"Star"
08.05.2020 16:11 # 11
34sea45
:) If the pump burns, that fun turns to torment in a moment :)
08.05.2020 16:11 # 12
zavur
there is gas in the vehicle, when i trust it, i will switch to the gas and vice versa. "Grin" />
08.05.2020 16:11 # 13
zavur
I realize that it is hard to be a student, so the vehicle will go to bed.
08.05.2020 16:11 # 14
34sea45
If you are working on the gas in the vehicle for the first time, you are pulling gasoline if the gas is cut even for 2 seconds.
08.05.2020 16:11 # 15
zavur
In 2 seconds, how can I master the petrol & nbsp; I will try to die half an hour, I do not know that there is no part of it, it did not work. building a half warehouse in one time & nbsp;
08.05.2020 16:11 # 16
34sea45
I did not work like that, even though I did not put gasoline, 250 TL was stuck in the pump :) worked when it was removed :)
08.05.2020 16:11 # 17
zavur
I guess the situation will be the same after a wink, my & nbsp; "Wall" "Wall" & nbsp; & nbsp; Reviews
