SOUND FROM FRONT CONSOLE
08.05.2020 17:02 # 1
mrkync
Friends started to hear from the front console recently. When the vehicle is running at idle, there is sound. I saw the torpedo section disassembled and I couldn't see anything moving. While working at idle, the sound stops when you press the ventilation hole on the right side. I'm sure the sound is definitely coming from the console. Has anyone encountered such a problem or knows the solution? They took me to the industry, they just said we would like 300 TL to remove the console. Come on len said from there I said: D Meanwhile the car 2005 peugeot 307 HDI 1.6 LOOK & nbsp;
08.05.2020 17:02 # 2
sukur
There's a grunt coming from me as if it's coming from the console, but I think it's a problem with Motor ears. It came to my mind, even if it was late. If it is like a grin, I say look
08.05.2020 17:02 # 3
selimvarlik
As I accelerate after the 4th gear, there is a friction sound coming from the air conditioning fans. It is interrupted and then it does it again. it just makes it hard. As the friend said, the guys want to insert the console without any guarantee :)
08.05.2020 17:02 # 4
mrkync
No, my teacher is not from the ears of the motor, but when I touch the place I said, the sound is not stopped. Sound inside is worth something on the console, but I can't find it.
08.05.2020 17:02 # 5
feline
definitely, after inserting the key in the ignition, start your car when it sounds, hold the key tightly, the sound will be cut, I searched for 1 year, it turned out that there was a small screw in the ignition, there was nothing that I did not relaxed, I had downloaded the complete indicators and vents below, but the problem came out in a place I did not expect at all & nbsp;
i think you If you try a & nbsp; luck you won't lose anything
08.05.2020 17:02 # 6
mrkync
Let's try it, let's see if the sound comes from there.
08.05.2020 17:02 # 7
mrkync
unfortunately the sound did not stop, but something caught my attention when I turned the steering wheel to the right, the sound increases, maybe this helps us find some trouble.
08.05.2020 17:02 # 8
heffera
There was a slight noise in me ... it does the squeak when the air conditioner is at 1.
08.05.2020 17:02 # 9
mrkync
how did you find the solution?
08.05.2020 17:02 # 10
haakaannn
Not much place but the fan that gives air inside is making a sound (the sound coming from the windshield coming from there) Is there any solution for me?
08.05.2020 17:02 # 11
ERSOY-06
The thing that mrkync is talking about and is uncomfortable is not related to mechanics. = "smileys / smiley20.gif" border = "0" alt = "Thumbs Up" title = "Thumbs Up" /> & nbsp; Regards
08.05.2020 17:02 # 12
spearo
pug vehicle tire pressure to 30 psi above the turkey naughty Check your tire You will see a lot of clapping you do is cut 29.
08.05.2020 17:02 # 13
mrkync
Friends I found the source of the sound. There are two pipes coming from the air conditioner in the engine compartment, and there is something like a plastic handle that holds the pipes plastic, it was broken and the pipes were making noise because of this.
08.05.2020 17:02 # 14
chemist32
Friends, too, my 307 car has a sizzle coming from the dashboard and it feels very obvious, especially when loaded on the gas. And the sound feels like it comes from glass. Please urgent help ???
08.05.2020 17:02 # 15
fthusl
I have the same problem, I have not been able to find a place in the past, I couldn't find it, the sound coming from the instrument panel started to get nervous and I decided to disassemble it again this weekend ...
08.05.2020 17:02 # 16
chemist32
if we find a solution please contact
08.05.2020 17:02 # 17
qqyyxx
It is natural that sounds come from various parts of the vehicles during heat exchange due to the laws of physics. No sound is heard easily from the torpedo of the 307s. I have not come across any of what I use. The sound coming from the ceiling lamp or the rearview mirror gives the feeling of coming from the torpedo. You have to examine well
08.05.2020 17:02 # 18
sezar206
Indeed, there is a lot of noise from the left of this piano. door trims, ceiling light, sunshades, trunk lock, especially sounds. There is not much room left, though;)
08.05.2020 17:02 # 19
ahmed206
[QUOTE = fatihpekgoz] really sounds a lot to the left of this piano. door trims, ceiling light, sunshades, trunk lock, especially sounds. There is not much room left anyway though;) [/ QUOTE] Slide the luggage lock down, the luggage noise is cut, lock the doors, the sound coming from the doors will decrease a little (I have no sound left). I wasn't sure if there was sound coming from the ceiling lamp, I heard the sun visors for the first time, but the seat belt (I heard it in many vehicles) also makes a sound, I don't know what to do with it.
