Sound from engine part 307
08.05.2020 19:38 # 1
burakrak53
. burakrak53 2016-03-10 16:13:23
08.05.2020 19:38 # 2
burakrak53
. burakrak53 2016-03-10 16:13:33
08.05.2020 19:38 # 3
yes it can cut but the problem will repeat in a short time. I recommend replacing the best v-belt and tensioner bearing. If the v-belt is around 30 TL, only if you change the roller, it will be around 100-150 TL if the complete log changes with around 40-60 TL. max. It has a workmanship of 50 TL.
08.05.2020 19:38 # 4
burakrak53
. burakrak53 2016-03-10 16:13:53
08.05.2020 19:38 # 5
[QUOTE = burakrak53] I just called a service, the tensioner bearing with the billet + belt + fan belt (I don't understand what relevance) said 320 TL with workmanship. I explained the problem man said they need to change [/ QUOTE]
There are two belts, teacher, one v-belt and one timing belt. I wonder where he will put the other one and the price is high. nette 30 tl v-belt with original 145 tl billet bearing
