SOUND FROM ENGINE FRIENDS HELP
08.05.2020 18:45 # 1
gokhan.kavutcu
ARKADASLAR SHOWED THIS SOUND FROM THE ENGINE TO 3 4 MASTERS BUT THERE ARE NOT UNDERSTANDING ANYTHING, THERE IS NO PROBLEM IN THE TROUBLE OF THE VEHICLE [BUT].
08.05.2020 18:45 # 2
muro_60
your blades are jumping wild, loose the big bounce coil, lift it up slightly, it may be in the flask, but it may be like a spark plug jump
08.05.2020 18:45 # 3
gokhan.kavutcu
Let me make them look at them.
08.05.2020 18:45 # 4
msertkol
Similar voice just discovered in my own car. The spark plugs have a top cap, and when you open it, a hose catches the eye. I think he's vacuuming for burning. My hose was just slit. Therefore, air cannot pass through it. I suggest you take a look.
While I was replacing the spark plugs, I cracked the original hose. Then I replaced a standard hose. But I think he was cracked from the heat. I think that's why.
Best regards.
08.05.2020 18:45 # 5
ank06sf940
check my friend then you can start the engine like me 1000 tl going
08.05.2020 18:45 # 6
ank06sf940
also is this sound high speed? how to work in the morning? I was there when the car got on the load, there was no upper revs, python skirt sound, bed sound was too many. :)
08.05.2020 18:45 # 7
suppor
A sound like this has changed from a pulley, the problem has been solved, but I hope this has hit the series, plug it, hwm, my car has been diesel, I hope I helped
08.05.2020 18:45 # 8
msertkol
I changed this oil hose this morning. I learned this if it was called oil air hose. I tied it myself and also attached a clamp to the top.
There was a little bit of noise after wearing it. I started the car and went to the master. I said, do you listen to the sound in the engine? He looked at it, but thanks. I think there was a moment when the master didn't hear. We listened a lot. There is no traction or performance problems in the car right now. Did I press the gas again, it is jumping. For your information, best regards.
08.05.2020 18:45 # 9
ank06sf940
Did the problem go away?
08.05.2020 18:46 # 10
206x-line
My brother may sound silly, but if I present a proposal, if your car has a crankcase, it can sound like this if the room touches the strained rail :(
08.05.2020 18:46 # 11
gokhan.kavutcu
friends, the problem has improved, the spark plugs are coming from the spark plugs are finished, I officially got new ones.
08.05.2020 18:46 # 12
samet206
It makes this kind of sound from the spark plug, I can not tell if the valve adjustment is in the car, what series is there or not, it can be a v-belt, gasoline valve can be checked ...
08.05.2020 18:46 # 13
ank06sf940
interestingly, our engine wasted :)
08.05.2020 18:46 # 14
ank06sf940
Was this sound only at idle, was it at upper speeds?
08.05.2020 18:46 # 15
blazes06
Get well soon. I say look at the sound gaskets as if they are coming from the Intake Manifold ... If you suspect the sound of the mattress, open the oil cap, listen through the sound ... If the sound of the cap is excessive, you will have a riding bed. but most likely it was the intake manifold.
08.05.2020 18:46 # 16
msertkol
Thanks for your friends comments.
Sound still exists. I don't think it's spark plug, but I can't say it's not certain. After all, it is necessary to open it. I showed it to 1-2 masters, they said it could be from V-belt tensioner ball. But he's still in the mood. There is idle sound when the morning is cold. There is also at high speed, very few, I can understand from the engine. The engine has no problem with comfortable traction, but there is a bit of noise. Today I will record the sound and share it here.
08.05.2020 18:46 # 17
maestro
When the gas is pressed, the sound becomes more frequent. maestro 2014-09-21 15:43:35
08.05.2020 18:46 # 18
msertkol
It's very thin, it's not called tightening. I don't know what the cup is ..?
Respects.
