SOUND FROM COLD ENGINE
08.05.2020 15:17 # 1
yldrms
Unhappy Slm. From my peugeot206 x-line 2005 model, when the engine is cold in the morning, a cracking noise comes from the engine. When the engine gets hot, the noise is reduced. I'm in the circuit, I changed the belt. Then they said from the battery. I would appreciate if those with knowledge can help ..
08.05.2020 15:17 # 2
Yusuf Tekoglu
Is Gasoline Diesel?
08.05.2020 15:17 # 3
yldrms
working on the first diaper in the morning with gasoline and lpg
then the sound becomes too much ..
08.05.2020 15:17 # 4
Yusuf Tekoglu
I Have No Information About Gasoline I Have X Line Diesel.
08.05.2020 15:17 # 5
[QUOTE = yldrms]
I think change your engine oil and use slightly thinner oil.
Then add antifreeze by changing your radiator water.
These come to my mind.
Best regards.
08.05.2020 15:17 # 6
Is the strap you wear is original? in the sub-industries again
