Sound from Brakes
08.05.2020 17:56 # 1
efesbright
Friends sound out of brakes :) Of course, I don't know if this is a chronic thing happening every 207, but my friends are getting on my vehicle, for example, I feel like I'm getting into a scrap vehicle like a disgrace ..
When I touch the brake lightly, a strange subtle treble sounds. I also come from these iett buses and other vehicles. The reason was the use of hard pad, the master in the industry, but the problem of fixing trw's soft pad was not improved. This voice is more intense in wet weather.
Except for this sound, when it is about to stop, there is a strange humming sound with a slight vibration. When the load on the vehicle is high from the brakes, this hum is more and the tremor is more severe.
what is the reason for this? Is it necessary to replace the discs or are the pads?
I hope I could describe the sounds.
08.05.2020 17:56 # 2
Alicilik
Hodja, I say have the discs checked. If you also changed the pad, the problem is directed to the disk.
08.05.2020 17:56 # 3
volkanC2
Not every trw is not original, let me tell you first, brother, we produce the pad, I am in this business :) How can I tell if it is original? I know :) get well soon ..
08.05.2020 17:56 # 4
efesbright
I don't know when the disks last changed. The masters I showed say that the discs look good every time, but this sound makes you crazy, so there is definitely a problem somewhere. I bought trw soft pad for 60tl in bostancı auto industry. I don't understand if you said it was original, but it seemed original until the colorful hologram on the box.
08.05.2020 17:56 # 5
Alicilik
[QUOTE = efesbright] because I don't know when the discs last changed. The masters I showed say that the discs look good every time, but this sound makes you crazy, so there is definitely a problem somewhere. I bought trw soft pad for 60tl in bostancı auto industry. I don't understand if you said it was original, but it seemed original until the colorful hologram on the box.
Since the new linings are reduced asbestos value, you have chosen this pest even softer and more soft than the old linings. How many kilometers is your vehicle?
08.05.2020 17:56 # 6
efesbright
In 165 thousand, my vehicle has become 15 thousand km. I replaced the pads with periodic maintenance. the master made a hard pad sound, he said it should be soft, we got soft but the sound started again after 500 km. I am shooting that problem, we are not able to find a solution. The masters in the market are going to change radically, saying that they need to open and clean the discs and drums.
efesbright 2013-09-09 17:35:19
08.05.2020 17:56 # 7
Alicilik
[QUOTE = efesbright] My vehicle was 165 thousand, 15 thousand km since it had pads. I replaced the pads with periodic maintenance. the master made a hard pad sound, he said it should be soft, we got soft but the sound started again after 500 km. I am shooting that problem, we are not able to find a solution. The masters in the market are going to change radically, saying that they need to open and clean the discs and drums.
Sound and vibration are related to disc and pad when you press the brake. If the disc is defective, it makes a faint sound and you feel shaking during braking.
I think you have a good master check your disks. If we can see a detailed photo of it, we can make good and bad comments.
08.05.2020 17:56 # 8
kivanc
I agree with friends who say we should go to discs.
08.05.2020 17:56 # 9
efesbright
yesterday, this voice got pretty intense :) you know how I tell you how it feels like the discs are running out. but I don't understand the masters says discs are good. Anyway, thanks to everyone, I think we will not be able to come to a conclusion without changing.
