Sound from 307 xs 2005 hdi gearbox
08.05.2020 17:03 # 1
heffera
if I push the car back slightly or pull the handbrake back and lift the foot from the clutch fully, the load is gently on the throttle and a gb noise is applied to the engine cartel .. what an important problem or what should I do ... I have to leave the car on a slope. Thanks for cvb.
08.05.2020 17:03 # 2
fexzi
Although my nurse did not fully understand what she wrote, I thought if there was a problem with the linings or tensioners, but I have no idea.
08.05.2020 17:03 # 3
berk2309
Is this just in gear, or when I'm idle, I'm going to sound like this
08.05.2020 17:03 # 4
heffera
Thanks for cvb. but I repeat. does not do empty assignment. not doing it in the flat area. he does it on the ramp to take off or on the ramp. There is nothing on fast departures. Normally, there is a sound like ciyykk :). rubbing the two metals together gb. I thought it was coming from the belt pulley, but the master said, although not sure, it comes from the gearbox. In the case of the handbrake, when the mechanic was in gear, apply the handbrake, gave light throttle, forced the car and made the same sound again. I expect help from those who offer solutions.
08.05.2020 17:03 # 5
[QUOTE = heffera] Thanks for cvb. but I repeat. does not do empty assignment. not doing it in the flat area. he does it on the ramp to take off or on the ramp. There is nothing on fast departures. Normally, there is a sound like ciyykk :). rubbing the two metals together gb. I thought it was coming from the belt pulley, but the master said, although not sure, it comes from the gearbox. In the case of the handbrake, when the mechanic was in gear, apply the handbrake, gave light throttle, forced the car and made the same sound again. I am waiting for help from those who offer solutions .. [/ QUOTE]
Can you describe the sound a little more? Is it a momentary voice, or is it sounding like a jumble, like a jumpy jump?
koliva 2012-09-19 21:27:24 < / editdat a>
08.05.2020 17:03 # 6
heffera
Let me say that the sound made when cutting the profile iron gb. stops when the car's movement increases. & nbsp; about 1 or 2 seconds.
08.05.2020 17:03 # 7
[QUOTE = heffera] Let me say that the sound that comes out when the profile is iron is gb. stops when the car's movement increases. & nbsp; for 1 or 2 seconds. [/ QUOTE]
Sounds are the most difficult topics to be solved in the forums because it is very difficult to explain exactly what the sound is and understand what has been told. Is water like a video? I hope not "Smile"
[TUBE] 7MQFFjg55nc [/ TUBE]
08.05.2020 17:03 # 8
heffera
The sound goes on here, the sound is short on me and the sound is not very similar. & nbsp; I try to throw the sound here after the game ... champions league. Thank you ..If you can help .. already, I would be glad.
08.05.2020 17:03 # 9
heffera
[TUBE] bQKyosWNB0o [/ TUBE]
this is the voice .....
08.05.2020 17:03 # 10
A child sounds in the 5th second but I couldn't get it out completely & nbsp; "Smile"
Are you sure this sound comes from the transmission? Reviews
