Sound from 307 1.6 engine
08.05.2020 20:40 # 1
eymengokhan
hi aleykum friends I just became a new member of the forum about 1 month ago I bought a 2006 model 307, there is a strange sound coming from the engine's engine under the timing cover, but I do not say to a few mechanic.
https://youtu.be/f73907fijbs
08.05.2020 20:40 # 2
eymengokhan
have no idea
08.05.2020 20:40 # 3
RP393
The sound did not give much idea but as a position there is a tensioner bearing. When it is broken, it makes bird sound. Will you try to remove and run the timing cover and the sound will change.
08.05.2020 20:40 # 4
eymengokhan
the car has a modified timing set last year, but a few masters say it can not be recycled in the bill, but if you notice that the sound engine does not change when it is cold, it sounds like vong vong does not sound when it is cool,
08.05.2020 20:40 # 5
RP393
Since the heated water will expand, the pressure increases inside. If the circulation is about to dissipate, it can be forced at this pressure and make a sound by making a gimbal. But this is something that I say completely predicted. In short, we cannot know the circulation without dismantling. If it has not changed for a long time, it will not be clear where my skin will change.
Also as it will change again in the timing. It will be a little salty. The decision is completely yours.
Let me add;
If it is caused by circulation, the frequency of the sound should increase when it gives gas. RP393 2017-12-02 12:47:38
08.05.2020 20:40 # 6
eymengokhan
I did not pay attention when I gave the gas, does the sound increase?
08.05.2020 20:40 # 7
eymengokhan
my teacher, I tried giving gas, the sound changes when it gives gas.
08.05.2020 20:40 # 8
emretprmz
Sir, the sound comes from the timing belt. It was either too tight or deformed. I went to the service last year with the same sound, the belt and pulley were deformed pulleys since the timing belt was installed tightly in the previous change. It cost 400 TL. I do not recommend that you get it done as soon as possible.
08.05.2020 20:40 # 9
eymengokhan
I understood, if the belt is tight, it is not possible to loose it, I said it was not possible to change it when it was removed.
08.05.2020 20:40 # 10
Akan evren
I think it comes from a tension ball
08.05.2020 20:40 # 11
eymengokhan
[QUOTE = Flowing universe] I think it comes from a tensioner ball [/ QUOTE]
but my teacher comes under the cover with the timing belt
08.05.2020 20:40 # 12
ggitaristt
Brother, this sound is like a hoop sound. If I was betting, I would invest money in my circulation.
The easiest is to remove the covers, take off the belt and turn the bearings by hand.
But as I said, if I were, I would play in my circulation.
08.05.2020 20:40 # 13
eymengokhan
I am thinking of taking it on Friday, if it is not clear before I disassemble it, I will change my complete timing, I think the timers have changed last year.
08.05.2020 20:40 # 14
ggitaristt
[QUOTE]
If you are sure that the triger has changed last year, there are 50000 ways of handling.
Also take good care of the charging belt and tension ball. It should change more often.
08.05.2020 20:40 # 15
eymengokhan
[QUOTE = ggitaristt] [QUOTE = eymengokhan] I am thinking of taking it on Friday. If I behave without dismantling, I will change my complete timing element.
There is a changed invoice, but the circulation has not changed, the v belt has not changed in the bearing, so this circulation needs to be removed in complete timing for change.
08.05.2020 20:40 # 16
emretprmz
It would be like repetition, but I had changed it in 88.000 thousand authorized service, the circulation set was not changed.120 thousand sounded like this. The meat did not break while it was going to die.This box material has changed.It has only been intact, we have replaced it, normally it should have changed with the timing. The sound I heard in the video was the same. is not something that will cost money. emretprmz 2017-12-05 20:51:15
08.05.2020 20:40 # 17
eymengokhan
[QUOTE = emretprmz] will be like repetition, but I changed it in 88.000 thousand authorized service, the timing set was not changed.It sounded like 120 thousand.It was broken. Except for the circulation. Prayer, the prayer did not break while he was walking. This box has changed the material. The only solid circulation remained. The sound I heard in the video was the same. is not something that will cost money. [/ QUOTE]
Come on, my teacher, I just bought the vehicle, I am really depressed now and I have a bad mood.
08.05.2020 20:40 # 18
whisky
Nothing to cool from the vehicle. all vehicles can also incur costs. If you look at the bond, do not look at the mountain Sleepy
08.05.2020 20:40 # 19
Peugeot35
It is obvious that the sound of the bearing is the sound of the circulation to me, but there are multiple bearings attached to the belt, there are tension balls, there are charge dynamo balls, there is a pulley ball, there is an air conditioning compressor ball, but which one is there, it is one of the cheapest parts that start from the cheapest, that is, the tension bearing usually starts very quickly.
08.05.2020 20:40 # 20
eymengokhan
Let's see if we can take it to Friday and insha'Allah the problem is solved, I am afraid of it.
Page : / 2
