Sound from 306 front and rear wheels ..
08.05.2020 15:45 # 1
friends recently I had changed the motorized lower ear wedge ... I have not noticed since then .. I have heard a sound for the last week from the front .. when I suddenly break the steering wheel and at the ramp upwards, I hear a strange sound like a ruffle. i am sure .. a sound that has remained without oil .. i even got off the intermediate vehicle i took my hand to the front rims left normally right tire was very hot .. did anyone have an idea until the engine bottom ear chock was changing until it reaches the discs ..... ?? ?
you by_ 2011-07-04 14:57:52
08.05.2020 15:45 # 2
If the right is too hot, the brake pad is tightening. Because of its rubbing, heat is generated. When he leaves the steering wheel, he pulls to the side. And if it gets too hot, it will not go away when it presses the gas.
08.05.2020 15:45 # 3
apopeugeot
look at the rod rods
08.05.2020 15:45 # 4
there is an itch already .. something is missing in the master that day is certain .. let me take a look at the evening ..
08.05.2020 15:45 # 5
I lived in palio. The lining of the lining was turned into a pinch. It was burning red at dusk. The next day I got it made Spray on several places. My trouble was resolved. Probably yours is something like that.
08.05.2020 15:45 # 6
My trouble was resolved ... I went to the master that day, the wheel was pulled, the hydraulic was tightened with a syringe somewhere ... Then he took off the pads, he sanded a few places .. Then there were long, long screws, he removed them, greased with grease.
When I parked the car last night, when I applied the brake, the same sound came from the left rear wheel. When I applied the brake and pressed the brake, there was no sound. When I released the handbrake and pressed the brake, I did not understand the sound from the left rear wheel.
08.05.2020 15:45 # 7
[QUOTE] .
Sound from behind can be natural. Because you are behind the drum and the limiter ... The right rear wheel must be the torch behind the torsion. It is useful to look again.
08.05.2020 15:45 # 8
When you go to the master, take out the smell of cecoli :) think about where I am.
08.05.2020 15:45 # 9
I have the same sound in my squeaking sound but I do not solve the springs because my helix is not seated from it.
08.05.2020 15:45 # 10
[QUOTE = OKANKYM] I have the same sound on me, squeaking sound, but I hope we can dissolve the sport bow because my helix is cut off from it [I hope] / [QUOTE]
As soon as possible, I advise you to replace the eıbach with those of -3.5 cm ... Cutting a bow is a dangerous practice ...
08.05.2020 15:45 # 11
metin
ersin brother, you got the sound in front, get past, now it started at the back now change the subject title as the sound coming from behind (:
08.05.2020 15:45 # 12
[QUOTE = text] ersin brother you got the sound in front, get past, now it started at the back now change the subject title as the sound coming from behind (: [/ QUOTE]
god emi you SırıtmaSırıtma ok..old i am now text Kahkaha
08.05.2020 15:45 # 13
metin
is it okay brother Can you see if you do ():
08.05.2020 15:45 # 14
[QUOTE = text] wouldn't it be brother. Can't you see if I do (: [/ QUOTE]
wishes my waterfall text .. Handshake
08.05.2020 15:45 # 15
[QUOTE = CeCoLi] [QUOTE = by_ersin] my boredom is solved ... that day I went to the master, he pulled the wheel, the hydraulic stuff, somewhere with a syringe ... then he removed the pads, he sanded a few places .. then he had a long, long screw, he took them out with grease greased. passed trouble ..
When you go to the cecoli kartinge, remember that sound ... when the castle descends from the center to its parking lot ... that sound is that sound ... Sırıtma
