Sound from 206 timers
08.05.2020 19:14 # 1
keuz
Hello friends, the timing set of my 206 model 206 was recirculated and the tensioner roller replacement was made.After these operations, 2000 km was made and now the sound is coming from the timing section, 3 different masters gave the same idea and said that the timing would be very tense. o I made timing and valve settings for 3 different masters who gave the same idea to 3, I gave 200 lira each, despite spending 600 lira in total, the problem was not solved. I gave lira to the service from lie to the floor, so, even though I spend 800 liras you will understand, my problem still continues.
08.05.2020 19:14 # 2
senalcay
No matter who you changed the timing set, you would take it to him again when the problem occurred.
08.05.2020 19:14 # 3
skksomerrr
I have the same problem, too, the master said that it will not be a problem.
08.05.2020 19:14 # 4
keuz
Thank you for your suggestion, but my brother says that Karel Oto could not solve the problem, he says it would not be a problem, but I want to solve it because I am uncomfortable with the situation.
08.05.2020 19:14 # 5
skksomerrr
Especially when you are waiting in the lights, it is heard too much. I was told the same thing as İlker Oto. You solve the problem. How many model vehicles? 99 me
08.05.2020 19:14 # 6
keuz
Vehicle 2002 model sound is heard more in idle, there was less sound before, now it has increased, I think a friend recommended a timing change similar sound has improved after the timing change, the same problem has been in it. I hope you will solve your problem in a short time, brother ..
08.05.2020 19:14 # 7
mctrading
Hello my friend,
If the sound you are talking about especially when it comes to the engine of the vehicle, it sounds like a truck tractor truck from the left side, it definitely makes it from the crank pulley. because it doesn't sound like it does not make sense after 2000 km when it uses the triger for the first time, but the crank pulley may have started to disintegrate, I have a very good master in Bursa, I left the authorized service, I changed the truck 4-5,000 km before you, The truck was starting to make a lot of noise especially in the idle, I went to the master, I showed the master, the crankshaft was in a very bad state, we said, we would replace 10000 maintenance and the crankshaft pulley right now. work, if you have doubts about it, have it checked, let me not mislead you ... regards
08.05.2020 19:14 # 8
sezar206
There is no master in pejo in Eskisehir, even if the devotees are not satisfied. They speak by heart. Karel auto is already saturated. Get in the wake of simple things, do the work you know that will tell you money. From the water malfunction to the Eskisehir industry, do not drop the pattern ugrasmzlr.allah. If possible, show them in Ankara. I entered twice twice, I was officially disgusted with the old industry or robbery. They don't understand shit. The ball in my socket makes a sound, ilker auto, my teacher, there is no sound, there was a place opposite the park and there was not a square. Bakti ball sound says all yqpar. La does it all, but why did he not? I got it done as if it was free. One trips one air ..
08.05.2020 19:14 # 9
keuz
I take into consideration the suggestion of the crank pulley bro, thank you very much for your attention, by the way, as it is mentioned in Eskişehir, the real master is absolutely absent or we couldn't meet it. You are the money, you will be awful, nothing else, let's not mind them. Let's see if they have a problem with the crankshaft change this week.
08.05.2020 19:14 # 10
skksomerrr
Let us know when you deal with the tiger and the sound problem.
08.05.2020 19:14 # 11
keuz
After the timing set change, the sound went 90%. keuze 2015-05-03 11:29:31
08.05.2020 19:14 # 12
berk2309
how are you talking about the sound of the metal knock sound like me? I also have the tension in the original sets, the triche makes it sound like the metal surtuyomus in the intent.
08.05.2020 19:14 # 13
keuz
not like metal rubbing, it sounds more like a bearing sound, a sound like a rolling bearing, more sound coming out when the car warms up, but it is said that there is no problem with the bearings or pulleys there is no solution other than believing that there is no hope that the sound will decrease soon. This is my only wish to remain ...
08.05.2020 19:14 # 14
Mevlut
If it sounds like a deep throat, the timing is too tight, if it sounds like a broken steering pump, remove the v-belt bearing v-belt and listen again to see if the same sound continues
08.05.2020 19:14 # 15
mightlacin
The brother may be from the tensioner or the hoop if the sound comes at idle. In the 206's, the tensioned pulleys are quickly leaving ... you can follow the sound by giving a little light gas while the engine is idling and pressing the pulley and tensioner with the help of a stick. or you can ask the mechanic to check.
08.05.2020 19:14 # 16
ramtas
friends, I want to ask something when the subject of the trilogy has been opened. How many years does this 307 1.6 gasoline timers change?
08.05.2020 19:14 # 17
berk2309
5 years or 70,000 to 80,000 I change every 2 years 20,000 to 25,000
08.05.2020 19:14 # 18
endars13
[QUOTE = mctrading] Hello friend,
this problem happened to me, too, after the timing change, just like the truck sound started to be heard, there was no performance loss in the vehicle, I showed it to the master. When the gas is loaded on the sound, I am bursa, who is your master?
08.05.2020 19:14 # 19
keuz
Unfortunately, I couldn't solve my problem with the master because all of them learned the logic of disassemble the new one, so none of them is a master. Since I knew this well, I found the case by searching the internet, and I learned another circulation pump that needs to be replaced with the timing set. If these pumps are not installed properly, the bearings of the engine breakdown after a certain period of time due to the heating of the engine water, and I did not believe that the reason for the expansion of the bearings began due to the heating of the engine water. I wanted to give money to 100 lira pump, 100 lira of labor, at least I wanted to try the change, and as a result, I stopped my problem by researching in the forums.
