Sound from 106 transmission
08.05.2020 18:29 # 1
yawruaslan
I said let me put the car in maintenance for summer is coming. The sound of the front right wheel was already recently, I took it to the master, he said that the right axle head should be changed.
the yawruasl 2014-04-30 22:22:19
08.05.2020 18:29 # 2
GokhaN
falcon peugeot ümraniye 0216 631 10 80
08.05.2020 18:29 # 3
Şahin Peugeot is good, even if we don't have a sponsor, they will make the necessary discounts when they go.
08.05.2020 18:29 # 4
yawruaslan
I bought the parts ... Front right axle, timing set and belt, front brake discs and pads, filters engine and transmission oil, I put the car into service today. moon . All the pieces I bought cost 450 pounds
08.05.2020 18:29 # 5
herry
What price did the master want to wear, whether the parts were good or not?
08.05.2020 18:29 # 6
yawruaslan
I did not talk about crafting, my friend from the neighborhood, I do not think that I will give a lot of workmanship.
08.05.2020 18:29 # 7
herry
super Thumbs Up
08.05.2020 18:29 # 8
yawruaslan
My friends, the important vehicle has gone, the parts have changed, but when the car is going, it seems like the balls are scattered or clicks, it sounds, the sound continues, I think the problem seems to be because the gear is empty, this sound is coming and you want to shift into gear, this sound increases a bit later, it continues in your old intensity. I think I will download
08.05.2020 18:29 # 9
yawruaslan
I do not understand much, if the gear was broken in the gear or something, did I change the gear to the gear?
08.05.2020 18:29 # 10
outlaw
THE TRANSMISSION PROBLEM MAKES THE SOUND AS THE VEHICLE DRIVES TO THE PLACE WHEN THE VEHICLE GOES TO THE SHIFT.
IS IT SO ON YOU?
WHEN IT IS DISAPPEARED, THE SOUND IS CUT OFF ...
08.05.2020 18:29 # 11
yawruaslan
I am not sure if my brother is both in gear and coming from the station, and I am not sure of the sound of the engine and the exhaust sound, as I am not sure, I am not sure about the engine and the exhaust sound. But if I say the problem is still going on, the car crash is going to be separated separately, not in such a car.
08.05.2020 18:29 # 12
okankrgz
Determine where the sound is glowing. steering vibration when braking is due to rod adjustments and front tool shortage ...
08.05.2020 18:29 # 13
yawruaslan
[QUOTE = okankrgz]
Determine where the sound is glowing. steering vibration when braking is due to rod adjustments and front tool shortage ... [/ QUOTE]
There is a broken gear in the gearbox, but there was no problem like shifting from the gear or not passing, but the master said he was blown up and he said that if you go and buy the parts, it will be expensive.
