Sound coming while the vehicle is walking in gear
08.05.2020 18:44 # 1
uniteksasli
As I mentioned in the topic, only the sound is heard when the vehicle is in gear. Thank goodness, the gear shifting, the traction, the speed, the gas eating etc ... there is no problem. Fortunately, there is no electronic error.
But when the vehicle is in motion, that is, in gear, it sounds like a tactic as it accelerates and the revs increase. If this sound, for example, comes as a tactak as soon as you plug it into 2nd gear, it can be heard comfortably that when it reaches 3000 speeds in 2nd gear or as the speed increases, it increases rapidly. In other words, according to the speed, the sound increases and increases.
When we press the drain during gear changes, the sound goes away. The sound continues when we shift into gear. We're wasting to try the sound goes again.
They said the transmission ball, we changed, with the pressure pad. But again, the sound continues. This time they said the mirror drive gears or they said the gearbox will change completely.
I can not make sense, when the vehicle is under load, there is sound, but when it comes out of the load, the sound goes out, when it is idle. And, as in paragraph 1, for me, it has nothing at all in gear gears, etc ...
Do the mirror and drive gears spin when the vehicle is in gear and idle?
Or just turns in gear?
the uniteksasl 2014-08-01 18:07:37
08.05.2020 18:44 # 2
35CUK97
My friend zip the car? change axle big possibility axle
08.05.2020 18:44 # 3
uniteksasli
As far as I have researched, how many axles do I call a gearbox gearbox and fasten it.
08.05.2020 18:44 # 4
uniteksasli
[QUOTE = 35CUK97] will you zip my friend car? change axle big possibility axle [/ QUOTE]
Do you zip? I couldn't fully understand but
08.05.2020 18:44 # 5
CrimsonChild
The motor ear may be broken.
08.05.2020 18:44 # 6
uniteksasli
Yes, anyone can guess, or someone who falls close to him?
08.05.2020 18:44 # 7
tutuman_307
CAN THERE BE A VOLTAGE FROM THE VOLTAGE DOES THE GAS BE LITTLE TO THE LEFT TO THE LEFT OF THE VEHICLE IN THE VEHICLE? OR STOP WHILE THE GAS LOADING VEHICLE GOES TO KNOW THE MOTOR WILL STILL UP TO THE MOTOR STOP IF THE MOTOR MAKES A VIBRATION IS A GREAT POSSIBLE tutuman_307 2014-12-12 10:19:51
