sound coming to the brake
08.05.2020 15:46 # 1
tilbe307
When friends pressed the brake while on the long road, why did the brake pressed a few times?
08.05.2020 15:46 # 2
berk2309
How did you say the sound of a crow?
08.05.2020 15:46 # 3
it could be from the heat .. it could be from the dust ... it could be from the brake center ... let's listen while you are using it in the city ... do you do it constantly or not ... for example the same problem started in me ... it was coming from the front wheel ... now it started in the left rear wheel ... probably Mine is from the brake center ... but I think you should follow ...
08.05.2020 15:46 # 4
tilbe307
Well, I couldn't describe it, I think it was taken out of the buses now.
08.05.2020 15:46 # 5
berk2309
dust or something has come between, if you have heard it for the first time, or if the pads have hardened, if you have a side industry or something, you will be braking too hard like bole on the hood.
08.05.2020 15:46 # 6
tilbe307
Yeah, did our pads lie like a buzzing sound?
08.05.2020 15:46 # 7
berk2309
If you do it, you can make sanding or if you stick it yourself and get the brightness on top, because the industry industry linings can get hot and cool, then you can get harder, it gets brighter, when you remove it, it passes with sandpaper, but you can use it in plenty. the surface of the one I removed was also rubbing it from the right side to the tire, and it sounded like donut, when it got too hot
08.05.2020 15:46 # 8
If the pads get too hot, it may make noise.
08.05.2020 15:46 # 9
sahin-peugeot
If your pads make a sound close to the end, if you want to control it, you can also damage the discs
08.05.2020 15:46 # 10
tilbe307
yes, there were scratches on the verticals when I bought them. let me take a look, thank you for your comments
