sound coming to gas pressure
08.05.2020 14:18 # 1
trigger
hello friends
After the gear shift, when pressing the gas again or releasing the gas in the gear and pressing it again, a very thin `` exit '' sounds.
In recent days, when he left the gas, his voice started to change and he started to shake at idle. The vehicle was in 2004 206 1.4, at 40000. Does anyone have an idea
08.05.2020 14:18 # 2
vbmaster
Start with the cheapest one, get an injector cleaning additive.
08.05.2020 14:18 # 3
vbmaster
If there is a mess or something ...
08.05.2020 14:18 # 4
trigger
When the gear is idle, there is no sound when you press the gas. Press the gas in gear, as if a gap of a reel is being removed ....
08.05.2020 14:18 # 5
peugeotefe
It is caused by the charging belt according to your incoming voice recipe. It has nothing to do with the additive remotely. If you cut the soap or oil on the charging belt and make the sound cut, then take the zero charging belt and insert the sound.
08.05.2020 14:18 # 6
vbmaster
true i have no objection :)
08.05.2020 14:18 # 7
trigger
Thank you Mr. Efe. mostly when the engine is hot and 2300 is over 2500 revolutions ... if the sound is lost when soap or oil spills, you say the belt will change. is it dangerous as such?
08.05.2020 14:18 # 8
trigger
The friend at the service says let's look at the engine nuts or the exhaust throat.
08.05.2020 14:18 # 9
NeDeS
I did not look at anything, the same thing happened to me, though my vehicle was in transit 2006 and diesel, but it sounded like the gas was coming from the differential ... the sound was cut off ... The vehicle can neither peugeot nor gasoline in this way.
08.05.2020 14:18 # 10
trigger
I hesitate to stay on the road or be the harbinger of a bigger expense. thank you
08.05.2020 14:18 # 11
can32
If the car starts to pull forward, this is a sound that comes from the relaxation of the engine's ear, for example, if the car comes into gear when it comes to the car, presses the throttle or moves hard from where it stops. I say it is tight, you do not hold anything, at least you can save it without reaching more than ten ...
08.05.2020 14:18 # 12
trigger
There is more or less this sound in all movements of the gas while in gear. it is not heard in large gear and very light movements. & nbsp;
