Sound coming in motion
08.05.2020 19:45 # 1
Kansu
Could the gear changes be related to the breakdown of the brake light? When I brake hard, when I take off again, the sound of the blunt comes and continues. They couldn't find anything, they said they could last from the brake light. Vehicle auto
08.05.2020 19:45 # 2
usta307
How does my brother make mechanical sound to an electronic part
08.05.2020 19:45 # 3
Kansu
I couldn't understand it anyway, but the master said: the brake light acts as a sensor, he can't understand that you release the brake
08.05.2020 19:45 # 4
Kansu
Is there anyone to answer
08.05.2020 19:45 # 5
Replace the link in the link, your problem will probably be corrected. The brake light is not the brake light, it's the part they say. automatic gear 307 must be the same in the future.
http://www.peugeotmarket.com/peugeot-307-fren-musuru-orjınal,pr-538.html
08.05.2020 19:45 # 6
Kansu
I made him look at it, but they said it was solid. So how does it sound? If the transmission fails, if the vehicle sees 130 km / h, the vehicle is going without a problem.
08.05.2020 19:45 # 7
talip206
Brake Switch failure, not brake light, can knock in automatic gear. But it does knock when going from n to r, not from going to or from n to d. Or the vehicle gets harder than p. Since the Brake Switch is unable to do its job, it sends the message that the brake is pressed to the brain and knocks while you shift gear. But I don't think the knock on the normal way will be due to the brake sender.
The sound of the mass coming to sudden gas pressure comes from the engine ear or transmission ear. It transmits the engine swing to Chassis. Most likely the problem is from the engine or transmission ear talip206 2016-04-22 21:27:30
08.05.2020 19:45 # 8
usta307
My brother, look at your transmission, the shock absorber mounts have axles checked.
08.05.2020 19:45 # 9
talip206
I noticed later what you wrote as the previous blunt sound. The problem you're talking about looks like a transmission issue
08.05.2020 19:45 # 10
Kansu
I have been using it for a few days. If there is a transmission in the vehicle, will it be used?
08.05.2020 19:45 # 11
lamazibici06
not brake brake, it was tight in the gearbox.
