sound coming from behind :)
08.05.2020 16:11 # 1
friends, there is a sound in the back of the car, when I enter the pit very violently. He said that the master wheel chocks should be changed. I have 307 friends, never mind changing the room. can you help me_
08.05.2020 16:11 # 2
34sea45
What does it mean that it does not work?
I think the piece whose life expires is so simple but I think it is the problem with it?
08.05.2020 16:11 # 3
zavur
my voice was coming from behind, if you ask the master, he will say something, but I looked at the hood, the sound of the oyapıo, I do not want to say that, but & nbsp; ask a master more and see if there is a way to get it done cheaply & nbsp;
08.05.2020 16:11 # 4
no & nbsp; this voice teacher is missing a certain voice, as there is something missing, there is this axle wedge when you make the expertise of the vehicle. If your friend says that it is not working, even if that wedge changes, the sound of the 307 suspensions is hard from behind. I'm making shortcomings slowly
08.05.2020 16:11 # 5
ByHack
My friend, first of all, the vehicle is auspicious, Allah should not cause trouble. Let God not touch the wheel of Anatolia with the expression of Anatolia :)
& nbsp;
Let's come to the problem you are experiencing; This problem is unfortunately annoying that I have suffered, and although I went to 3-4 different services, it is called "there is no solution". Especially when I sit 2-3 people in the back, it's okay, it hits at the slightest fluctuation, as there is no shock absorber. I couldn't find the solution brother, some said the damper chock, some said the torsion bushings (the most ridiculous thing is that the shock absorber has a blower generally from the duser slot, 250 grams of plastic is now shaking without understanding).
& nbsp;
let me know if you find the solution ....
08.05.2020 16:11 # 6
metin
friends, the solution is here, I had the same problem as of me since the day I did, there is no sound
& nbsp;
cost 2.5 tl
& nbsp;
08.05.2020 16:11 # 7
I was thinking about spending time for the car tomorrow. It was good that I heard about it. Let me go with the silicone gun tomorrow. Well, let me ask you, does the rear traverse bush erroneous in expertise cause trouble if the axle wedge is not changed with the words of the master?
08.05.2020 16:11 # 8
I faced the same situation, I changed the shock absorbers day by day, but again it makes a noise. I am skeptical of torsion
08.05.2020 16:11 # 9
What is torsion, where is my teacher?
08.05.2020 16:11 # 10
metin
[QUOTE = htasay] What is torsion, where is my teacher? [/ QUOTE]
& nbsp;
don't worry :) :) There are shock absorbers and springs in the back as well as in front, because niyo friend is 206, there is torsion in the back instead of spring, no springs.
08.05.2020 16:11 # 11
I can not learn the name of these pieces somehow :)
08.05.2020 16:11 # 12
and the sound coming from the back of the 307 is cut :) The result of the application we made with the advice of our text friend is the sound coming from the back is history :) thanks my friend :)
08.05.2020 16:11 # 13
musictime
I recommend you change it costs about 250 TL. My balls were scattered. The tire breaks off.
08.05.2020 16:11 # 14
teacher, it was not a malfunction malfunction in me. They said it would make the axle wedges. Then my text teacher recommended me to stick the shock absorber bellows up. yesterday i applied today the trouble is over :)
08.05.2020 16:11 # 15
metin
[QUOTE = htasay] and the sound of the 307 from behind is cut out :) Thanks to the advice of our text friend, the sound coming from the back is history :) thank you friend:) [/ QUOTE]
& nbsp;
, I was very happy. (:
& nbsp;
goodbye. Happy! "20" width = "20" border = "0" alt = "Laugh" title = "Laugh" />
& nbsp;
& nbsp;
08.05.2020 16:11 # 16
oguzhan29
glad to solve the problem of my brother, well it wasn't a big thing
oguzhan29 2011-10-06 16: 50:55
08.05.2020 16:11 # 17
thank you teacher
