sound coming from behind
Homepage » PEUGEOT MODIFIED PLATFORM » 106
08.05.2020 15:07 # 1
onurozturk
Hello friends, I just joined the site. Greetings to everyone
I have a 99 model 106 gti car. The title has been opened before, but the sound from my car had to open a new subject from a different rating.
As my vehicle passed through the car, a creaking sound began to come from behind.
As an example of sound, for example, when you stop with the vehicle on the slope and pull the handbrake after it comes out of the vehicle, it sounds like a squeak, since the hand brake holds the rear wheels.
the same sound comes from behind as it passes through the bumps. Is it from torsion? If not, it is related to shock absorbers.
I'm waiting for your help from administrators and site members
respects
08.05.2020 15:07 # 2
peugeotefe
Torsion shaft 13 bolt is broken, remove the right rear wheel, you will see it right there
08.05.2020 15:07 # 3
klemann
[QUOTE = peugeotefe] Torsion shaft 13 bolt is broken, remove the right rear wheel, you will see it right there [/ QUOTE]
Whether halal: DD
08.05.2020 15:07 # 4
Carmania
Ewet is in my opinion, if it is broken, it will already be threaded, it is already metric 8.
08.05.2020 15:07 # 5
metin
Look at the masters and they solved it technically.
08.05.2020 15:07 # 6
Efe, I think the same problem is present in me. I have started to feel a slight squeak for 2-3 days.
I hear that squeak when the brakes hold or take off
08.05.2020 15:07 # 7
maslakpeugeot
[QUOTE = onurozturk] friends hello. I just joined the site. Greetings to everyone
respects
Hi dude, there is definitely a problem with your totion in your vehicle. If the balance iron has been thinning, I will help you if you are in Istanbul: D
08.05.2020 15:07 # 8
peugeotefe
[QUOTE = albaydemircan] efe I think the same problem is present in me, I have started to feel a slight creak for 2-3 days
Come in time of Musait, drink our tea and look at it
08.05.2020 15:07 # 9
saivet
Hi bro, I have the same problem with me.
08.05.2020 15:07 # 10
saivet
I HAVE LOOKED TO THE MASTER, THAT IS NOT TORSION, I WILL NOT RECEIVE WHAT I HAVE RECEIVED BEFORE THE BACK WHEEL IS THE BREAKING SOUND, I CAN'T ALSO HAVE BEEN TO BE READY TO GET TO BE SOMEWHERE CAN I HAVE TO BE READY TO HELP THAT I CAN'T ALSO HAVE BEEN ALSO HAVE TO BE REPORTED
