Sound comes from clutch pedal
08.05.2020 19:23 # 1
bozlak
When my car peugeot 206 pressed the clutch, it sounded like a snap, the clutch remained flat when I pressed the last clutch, then it got better, then it did not go to gear. We have to look at it. I wonder if I have encountered such a problem?
08.05.2020 19:23 # 2
mhrcyn
It happened to me about a month ago, the clutch wire was broken, I was on the road, be careful.
08.05.2020 19:23 # 3
bozlak
[QUOTE = mhrcyn] It happened to me about a month ago, the clutch wire is broken, I was stuck on the road.
Did you have the same things?
08.05.2020 19:23 # 4
samet206
If the clutch wire breaks off, you will be on the road then it won't be good for you ...
08.05.2020 19:23 # 5
mhrcyn
Yes, and the car contact was locked, there was no vehicle behind me, I did not apply the hand brake, the steering wheel was not locked and braked.
