Sound comes from belt or pulley Help !!!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:09 # 1
mursip
[TUBE] ooyvfnh8bj the [/ TUBE]
The sound comes out like a ball sound from the vehicle. Since my location is a small district, there is not much that understands here. I showed it to the master, he could have said the air conditioning ball, I asked the other master on the phone, I need to see it from the pulley or the belt. they will investigate the reason and I do not want to go back because there is no piece, I think the problem would be better to understand first)
I would be glad if the writer with the knowledge.
08.05.2020 15:09 # 2
volkan_uysal
I showed it to me last week.
The voice is coming from the apricot, I changed it, but the new one has a voice that is close to the old one, and I hear it very clearly.
It comes together from the bearing of the engine of the sub-unit. But I think you are too much from my air conditioner ball!
08.05.2020 15:09 # 3
mursip
The problem was from the alternator belt. The problem was changed. Çorum Peugeut service was also very relevant. the albaydemirc 2011-06-10 13:25:33
08.05.2020 15:09 # 4
gkndrc
it happened to me the bottom wheel locks up making sounds locks while turning then continues
then it gets locked ....
08.05.2020 15:09 # 5
gkndrc
did you have the same problem
08.05.2020 15:09 # 6
http://forum.peugeotturkey.com/forum_posts.asp?tıd=7516&pıd=105511&title=yeni-yelerin-dikkatine-konu-amadan-okuyunuz#105511
08.05.2020 15:09 # 7
nteker
My friend had the same problem in my vehicle, this issue was opened before. I am glad that the problem is solved, I hope it is not a problem like mine. Because maybe you can hear the same sound in 1-2 months after the alternator belt changes (I hope it was so, I hope you will not stay with it). If the sound is the same, look at the alternator tensioner bearing and replace it with auto if necessary
