Sound as the door opens
08.05.2020 15:54 # 1
werty
friends, I don't have any trouble nowadays
While the 1st driver's door hurts, I think it sounds like I think I can change an expensive part of myself with an upset tension,
2. On the way to the road, the tailgate started to make a sound, what can I do for this?
Thanks for your help
08.05.2020 15:54 # 2
berk2309
How can the tailgate make a sound, because the tires are worn out?
08.05.2020 15:54 # 3
werty
[QUOTE = berk2309] How can the tailgate make a sound because the tires are worn out [/ QUOTE]
There are strings on these roads and pespese, the trunk lid shakes as they pass over them
The room is making noise
08.05.2020 15:54 # 4
berk2309
either the trunk's shock absorbers have gone or look at their trunk, the trunk's tires are very crushed, it is making a sound now it is time to change.
08.05.2020 15:54 # 5
sezar206
Tighten the lock screws of the trunk lid may have loosened.
08.05.2020 15:54 # 6
My friend, such a small problem, may Allah not give the big one .. Check the luggage lock is too low or too high. What I will say for the door is that this happens in every car. I had a clio before. I had a fiat bravom. For my piece, my friend-pegeout will give you the best price
respects
08.05.2020 15:54 # 7
iibrahimm
I started listening to the baggage for a long time. I've been listening for a while. I noticed that it came from the baggage week, but I couldn't decide the lock or my tires. creaking noise like rusty iron
08.05.2020 15:54 # 8
tilbe307
friends, I had the same problem. then the results of my research, if it is the same squeak, comes from the plastic that we hold when closing the trunk, a shrill and disturbing sound inside the baggage hood. we disassemble and lubricate it with the help of a screwdriver. interlocking iron parts are already crowding. I found the solution like that
08.05.2020 15:54 # 9
okan77
it sounds like it shouldn't be too much
08.05.2020 15:54 # 10
werty
The 1st reason of the sound in the trunk lid is loosened.
When I came to the door, I went to the eagle auto industry, I got 206 door tensioners, I removed the door tension, I changed the tension, the piece was priced at 50 lira, but I had to take it from the absence of anything to do, I did not take the photos of my phone, my phone was gone. But if there is a friend to change, I will try to explain as much as I can. The door was sizzling, and I changed the segments of the door trim.
08.05.2020 15:54 # 11
let's get past
08.05.2020 15:54 # 12
Muhammet CAKIR
[QUOTE = iibrahimm] baggage started making noise in me I have been listening for a long time. a squeak like rusty iron makes a sound [/ QUOTE] it might be coming from the back seats :)
08.05.2020 15:54 # 13
harmus
[QUOTE = fatihpekgoz] Tighten the lock screws of the trunk lid may have loosened. I was doing it too. You can even easily tighten the lock or striker in yourself. Do not forget to pay attention to the right to left setting.
08.05.2020 15:54 # 14
sahin-peugeot
[QUOTE = wertyu]
50 tl is not expensive, they gave it at normal price, you should be comfortable :)
08.05.2020 15:54 # 15
werty
thank you for the information relieved =)
